Two go in and one comes out (Operation body swap)
    Originally posted by bomdoutscort View Post
    Where did you get the -4 an to 10mm x 1.5mm adapter? been looking around and knew some miata guys using them but couldn't remember where they were from.
    Summit Racing PN / 9919BFDERL
    Originally posted by Mazda_Powered View Post
    gotta love the interchangeability lol, what do you think you'll put down for numbers with that turbo? stage 1 turbine wheel is how big compared to the stock one?
    All depends on what I'm doing about ecu's, with the bp26 ecu im pretty limited, so it's probably a good idea to ditch it for something better. Even with the gtr ecu you can only do so much.. Idk yet, don't really have the cash for a standalone atm. Stage 1 wheels are stock, nothing special and I'll probably upgrade it down the road.
      Forgot to put these up earlier.
      Just an odd shot..
      Miata valve cover almost done. I'm going to make a wire cover for it, just need to get around to it.
        looking good!
          Thanks :D Anyone know if the red 2.3 mazdaspeed caps fit the bp?
            Test fit for compressor clocking. I see I'm going to have to figure something out to get the intake tube around the mount to the housing, maybe a 45 degree reducer would work. Look at how fast/much my manifold rusted sitting in the humid garage over night!!
              That looks very very clean.
              I can test fit the MS3 cap tonight for you - send me a PM for a reminder. Also remember that the 2010 and 2007-2009 oil caps for the Mazdaspeeds are different.
              Didn't the Mazdaspeed Miata come with a billet cap? Big downside to these is how hot they get.
                Wow the engine bay is super clean/sexy! Great work---can't wait to see it completed.
                sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
                  I figured as much with the caps, but if you have access to one go for it
                    The engine bay is so clean and nice and just use a 90* reducer or just use a 90* bend and use that size pipe. Its only an intake side of the turbo so...
                    "Who Dey"
                      Some new goodies arrived not too long ago Can you spot em?
                        oil cap, wastegate, breather filter on valvecover. Also where does the pcv valve go into the miata vc?
                        "Who Dey"
                          Breather is old and is just covering the hole to keep dust out while im doing stuff but that is where the pcv valve would go. I will be venting it to my catch can which freely vents out to the atmosphere, so there is no need for the valve anymore.
                            Such a tasteful/clean car...
                              If you're talking about the red one? Yeah, it fits. I've seen it on a couple miatas.
                              Broke Status FTW!
                                That vc is sex.
