Results 1 to 8 of 8
Thread: Timing belt... Crankshaft Lock Tool?
  1. #1
    Registered User textures2's Avatar
    Join Date
    Oct 2009
    Location
    San Jose, CA
    Posts
    62
    Feedback Score
    0
    Hi guys,
    I'm going to be tackling my timing belt/water pump, etc. probably next
    weekend on my 90 SE (B6).
    I understand that I will need a tool to lock the crankshaft pulley in
    place during removal (at least this is what the service manual tells
    me.)
    I've found a few products on the web, e.g.:
    http://shop.oreillyauto.com/ProductD...rtType=&PTSet=
    http://cgi.ebay.com/ebaymotors/ws/eB...m=310181197923
    First question is: is this the correct tool? If not, what should I be using?
    Secondly: the service manual illustrates SST 49D011-102. This tool
    has a long handle extending off of it, which would seem to be
    necessary to help you get the proper torque on the crank pulley. But
    the tool depicted in photos above doesn't have this? How is it used?
    Any guidance or tips -- greatly appreciated.
    Thanks!
  2. #2
    my name is a verb now Turpro's Avatar
    Join Date
    Jan 2004
    Location
    Cincinnati suburb Ohio
    Posts
    17,189
    Feedback Score
    73 (100%)
    No tool needed. Grab a friend/family member/loved one and have them sit in the dr seat putting the car in park/5th and pressing the brake. Then you go loosen/tighten that crank bolt . Free is good
    Quote Originally Posted by jay View Post
  3. #3
    Registered User MinkelR's Avatar
    Join Date
    Jan 2009
    Location
    Sedro-Woolley, WA
    Posts
    114
    Feedback Score
    1 (100%)
    You don't even need anybody to stomp on the brakes while you loosen it. Just put your socket and rest your ratchet/breaker bar firmly against the ground or unibody and bump the starter. It'll brake the crank bolt loose like nothing. Make sure to unplug your coil wire when you do this.
    Main thread because my explanation sucks: http://www.clubprotege.com/forum/showthread.php?t=18317
    1987 Acura Integra LS (Now Parting Out)
    1989 Acura Integra LS
    1992 Mazda 323 (Current DD)
  4. #4
    Registered User
    Join Date
    Sep 2003
    Location
    Ottawa ontario
    Posts
    1,550
    Feedback Score
    10 (100%)
    its 10$ I have one if your doing it alone its worth it.
  5. #5
    Join Date
    Oct 2009
    Location
    San Jose, CA
    Posts
    62
    Feedback Score
    0
    Thanks for all the replies. These ideas and suggestions are very helpful!
  6. #6
    crazy tire guy tireboy's Avatar
    Join Date
    Apr 2008
    Location
    surrey b.c.
    Posts
    1,064
    Feedback Score
    0
    impact gun ..... did water pump,t belt,new rad,thermostat,flush n fill entire cooling system . 3 hours....
  7. #7
    Join Date
    Oct 2009
    Location
    San Jose, CA
    Posts
    62
    Feedback Score
    0
    Quote Originally Posted by Turpro View Post
    This trick worked like a charm. Thank you!
  8. #8
    Join Date
    Jan 2004
    Location
    Posts
    17,189
    Feedback Score
    73 (100%)
Thread Information
Users Browsing this Thread
Similar Threads
  1. timing belt/water pump/alt. belt help needed
    By protozoom in forum Engine/Drivetrain - BJ Chassis
    Last Post: 08-06-2012, 11:50 AM
  2. Timing belt
    By alexplicit in forum General Discussion - BJ Chassis
    Last Post: 07-26-2012, 12:40 PM
  3. Timing belt, Crankshaft mark 1.5l please help
    By Mazda bpt in forum Engine/Drivetrain - BHA Chassis
    Last Post: 05-16-2009, 12:45 PM
  4. Replacing the Power Steering Belt: Can't Find the Tension Lock Bolt
    By Karyyk in forum General Discussion - BJ Chassis
    Last Post: 05-08-2009, 08:26 AM
  5. timing belt special tool?
    By RonBurgundy in forum Engine/Drivetrain - BG Chassis
    Last Post: 05-25-2007, 11:36 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
