Hey guys once again i am having a problem with my Mazdaspeed protege. I need to replace my front hub. what i need to know from someone who has already done this is will i be able to get my hub off without destroying my wheel bearing or am i going to definitely replace my wheel bearing. From the diagram i have it looks like it slides out but i am pretty sure its pressed into the center of the bearing. Can someone give my info on this issue and how to resolve it. Thanks
Wheel hub
you definitely need to replace your wheelbearing. theres no real way around it.
snap ring>bearing-Bearings are not very expensive - i do recommend doing both sides @ the same time however, if @ all possible ---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
