My 1994 Protege DX still has the 13" stock wheels, and nowaways 13" tires are not as easy to get. I may be able to get a set of 14" wheels from a 95 Honda Civic (4-lug also). Will they fit on my Protege?
Will 95 Honda Civic Wheels fit on 94 Protege?
yesEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Yes. Remember to buy lower profile tires to maintain overall wheel / tire diameter.
Civic wheels
size 14 x 5 in
lug pattern 4 x 100mm (same as Pro)
center bore 56.1mm (Pro is smaller by 2mm at 54.1mm so this is OK)
offset should be close enough
Moving wheels from one car to another can be complicated. I don't think it will be a problem, but you might size up some tires to maintain the overall diameter and be sure they will fit on the relatively narrow 5 inch wide wheel.
hubcentric spacers are needed for this, the lug nuts are not supposed to carry the weight. 2mm like stated above.
Easiest bet? Mazda rims.-Jack
yea. i took sum 18s off my old integra and swapped over to my escort and didnt have to change anything. just gotta make sure u get lower profile tires so u dont scrub the strut perches1993 Ford Escort GT-T
1992 Mazda Mx3 GS((Parting Out))
1994 Honda Integra LsVtec-Sold
1984 Toyota Corolla SR5-Sold
1983 Ford Ranger-Sold
My Turbo Escort GT build thread
My HUGE f/s thread. Go buy!!!
Myspace yooo
Thanks for the info. I definitely not want to run on bent lug nuts if this is the case.
Experience with my late 91 Camry seems to show lug nuts are easy to break.
Would 14" wheels from Escort are a direct fit?
Originally posted by Mazda_Powered View Posthubcentric spacers are needed for this, the lug nuts are not supposed to carry the weight. 2mm like stated above.
Should be. Yes.1990 Protege 4WD
1 3 5
2 4 R
--FerdiIf you can't differentiate between brake and break, you should go back to school
you will be fine with honda rims. the center bore on the hondas are bigger then the mazda, so you don't have to worry about that. just make sure you have the acorn lug nuts and torque your wheels (i.e. each lug nut) a bit at a time and it will center it for you. i've ran numerous honda wheels or wheels with larger center bores, never got hub-centric rings, and just do as i say, and it always centers for me.Create your own VB Gallery here.
^Um, exactly right. Your lugs should be more than strong enough to hold the tire to the hub. Hub centering rings only "center" the wheel to the hub so there is no vibration. This centering is usually only a big deal if you're taking on much bigger wheels. Toss those 15s on and enjoy them. If the center bore was too small that would be a problem.
I ran crx 14s on my last protege. You'll be fine1993 Protege LX-Midnight's shadow SOLD
Originally posted by jay.....they totally underestimated the number of gearheads such as myself that have families but refuse to grow the hell up and stop playing with cars, or that otherwise see the utility of having 4 doors. Obviously I ain't alone, as there are a helluva lotta sti and evo here. Bueler? Beuler? Mazda? Mazda?
i run aftermarket wheels with large center bores and no hubcentric spacers for my drag slicks. no problems...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
no problems 11 sec at a time.... UPDATE UR SIG JON!!!!
94 Pro LX- 3-hole. Familia seats, Infini Corners, Familia Grille, Familia Rear Garnish w/Rear fogs EDM Glass headlights,
MSP Mazdaspeed Muffler,Mazdaspeed front strut bar,'00 Pro ES wheels, Neuspeed Springs,GR2s, MX3 wheel, MX3 Tall armrest
Originally posted by 90lsturbo View Postshould fit if not get them off a integra they will fit for sure1993 Protege LX-Midnight's shadow SOLD
