4WD Shifter Cable BRASS Bushings (transmission end)
    Yes there are 2 really informative threads on fordlaser.com
    idk if you saw these threads, but it might be a good idea to get the pieces.
    the first thread has the mazda part # for the blue bushings.
    the second thread has great pictures/ford part numbers.
    go grab those bits if you haven't already.
      You could make your own like I did. It's really cheap that way, and it's brass.
      1990 Protege 4WD
      1 3 5
      2 4 R
        post a picture of it please
          I made a thread about it. Here is a link. There is another one in my signature.
          1990 Protege 4WD
          1 3 5
          2 4 R
            Good info! I cant wait to have a nice and tight shifter
              Any updates? I made a set of the ones on the shifter that where bad on mine. I'm not afraid to make some outta metal.
              Used a drill as a lathe.
              need help with my gtx
              http://. please check out my welcomi...ad.php?t=52356
              looking for info on the 626 master cylinder upgrade
                More info please
                  Follow the link posted. If you want more information than that, ask a specific question in that thread. This one is about the cable bushings.
                  1990 Protege 4WD
                  1 3 5
                  2 4 R
                    any updates? i read th ewhole thread and looks like two people got the bushings?
                      Which bushings? THIS thread is supposed to be about the availability of new TRANSMISSION END bushings, NOT shifter end bushings. Those few posts regarding the shifter end are sort of a threadjack, but at least it keeps the info in kind of the same place...
                        Yeah... sorry about that.
                        1990 Protege 4WD
                        1 3 5
                        2 4 R
                          heh, no problem, it IS ancillary, although tangential, and it's a good link, and something I plan on doing myself.
                          Of course, i'm not really sure if the ST-205 setup will actually need new bushings, and I won't find out until it's all installed, which is gonna be a ways out...
                          --sarge
                            I Was asking for a update from those who ordered.
                              What update? I got them and they're good. I'm satisfied.
                              1990 Protege 4WD
                              1 3 5
                              2 4 R
                                OK ya sorry I will just order and quit bothering you. I asked about an update because I saw That some posts mentioned slow orders and no email replies. So That the update I was asking about.
