Window motor rebuild
    This is a rebuild of the window motor from a 1988 GTX.
    You will need the following tools:
    #2 phillips head screwdriver
    8mm socket, either deep or with an extension
    flat head screw driver
    pliers
    snap ring pliers (maybe)
    1000 grit sandpaper
Name:	Tools Needed.jpg
    Here is a picture of the front side of a window motor assembly:
Name:	Front Side of Assembly.jpg
    Here is a picture of the back side of the same assembly:
Name:	Back Side of Assembly.jpg
    If you have not already done so, remove the clamp holding the plastic tube in place and remove the tube. There are a bunch of metal tabs accessible from the back side of the assembly. Straighten out all the tabs. Remove the small metal plate from the base near where the tube was. There are three screws holding the motor onto the plastic base. Remove these three screws. You can now remove the motor from the base.
Name:	Disassembled assembly.jpg
    Examine the drive gear. A good gear will look like this one from a passenger side:
Name:	Good Plastic Drive Gear.jpg
    A bad drive gear will look like this one:
Name:	Bad Plastic Drive Gear 1.jpg
    here is another picture of a bad gear:
Name:	Bad Plastic Drive Gear 2.jpg
    This will give you the click, click click sound. Unfortunetly, this part cannot be purchased seperately so if it looks like this, you either buy a new assembly or find a passenger to swap parts with.
    Here is a picture of two plastic chains:
Name:	Drive Chains.jpg
    Note the one on top has a lot of black stuff on it. This is the residue from the drive gear going bad. Clean off the drive chain and look for brown spots like these:
Name:	Bad Spot in Chain.jpg
    They indicate a spot where the click, click, clicking has fried the chain. This chain cannot be reused and was discarded.
    Now, let's take the motor apart. There are two phillips head screws at the base of the motor. Remove them then just pull the shell off the motor. You will see something like this:
Name:	Disassembled Motor.jpg
    Take a close look at the commutator end. In this picture you can see a black stripe arond the commutator:
Name:	Commutator Before.jpg
    using your 1000 grit sand paper, sand this black stuff off to get this:
Name:	Commutator After.jpg
    Stuff the commutator back into the shell, then stuff the motor back into drive gear assembly and put your two screws back in.
    Here is a picture of the plastic bases. Not that one has more black residue from the drive gear going bad. Clean up these pieces and spray them with lube.
Name:	Plastic Bases, Dirty and Dirtier.jpg
    After cleaning all parts and lubricating with your favorite soft grease, reassemble the parts. Make sure to stake the metal tabs down tightly!
    Comments?
    Bob
    Great write up. I had taken mine partialy apart to fix, lubed it and it helped a little but still slipping. Ill be trying this over the winter. Any idea if we can still get new chains or drive gears from mazda?(prob not)
    -93' Mazda Miata, half caged
    -09' Mercedes C63 AMG
      When I went, I had to order a full assembly, parts were not available. The next question is: What other cars used this system? From this we can then search junkyards for passenger side and/or rear door motor assemblies to salvage the gear and chain out of. Anyone????
      Bob
        rumors are that the 929 of the same era had the same style
          Yep..88-89 929 front doors only....front door also in second gen Escorts(much easier to find and up to 1995) have the exact same unit and are in my GTX #2 working fine.....of course look for a low mile car and you will be better off.
          Clay
            I know this is a BF thread.. but that sure looks like the BG power window assembly. Are you sure that sprocket isn't the same as dealer part # FB05-58-581 (approx. $14). It's impossible to see measurements in these pics but it might be worth while to compare a used BG sprocket. I have a few sitting around the shop.
            Here's the only picture I have available of that part number.
            miss my '93 LX at every corner
            photo album
            Catch me on Facebook
              I would guess it would work...if all else fails the BG regulators fit in the BF cars so just rebuild them and use them.
              Clay
                I used 626 motors when I installed power windows into my turboed 323 DX. Almost a perfect fit.
                sigpic Horsepower is the force that determines at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it.
                  looks very similar to my '89 tracer. passenger side wiper moves the gear, drivers does not...when i flick on the wipers nothing happens. what to do? fuse is good. "wiper" light is on in the dash.
                  ~LIVE FAST, DIE YOUNG~
                    Thank you for this post! Both my windows are having troubles going up I'll have to check if this is the issue.
                      Thanks for the information and tutorial. Much appreciated.
