Updated February 2011
Tools and Materials Required
3/8" drive torque wrench
3/8" drive ratchet
3" long extension attached to a 10 mm socket to remove and install the coil pack mounting bolts
6" extension attached to a 5/8" (16 mm) spark plug socket to remove and install the spark plugs
spark plug anti-seize lubricant and dielectric tuneup grease (I used Permatex brand)
Ignition System Configuration
There are two coil packs and each has a low-tension connector at one end and a high-tension spark plug lead at the other end. See photos below for a detailed view of the layout. One coil pack (incidently, Mazda refers to them simply as ignition coils) is mounted over, and energizes, the spark plug for No. 2 cylinder and is held in place on the cam cover with two mounting bolts. Its high-tension lead (the short one) connects to and energizes the no. 3 cylinder spark plug. The second coil pack is similarly mounted over the no. 4 cylinder spark plug and its high-tension lead (the long one) connects to the no. 1 cylinder spark plug. Underneath each coil pack, is a spring which applies pressure to a plug cap that physically and electrically connects the coil pack to the spark plug. Each high-tension wire has a similar plug cap, complete with boot (without the spring), integral with the wire. Because of this configuration, the system requires only two spark plug leads.
Spark Plugs
According to the FSM, the OEM specified plug for the FS-DE normally aspirated engine is the NGK V-Power BKR5E-11 or the Denso K16PR-U11 with nickel alloy (commonly, but erroneously, referred to as copper) electrodes. Alternatively, if you're following TheMAN's recommendation for substitution of an extended projected tip type (as I did), substitute the NGK V-Power NGK ZFR5F-11 (which is OEM for the 1.6 L ZM-DE engine) in place of the FS-DE factory recommendation.
http://www.imazda.com/forums/showthread.php?t=142
The electrode gap for either type is OEM specified as 1.0-1.1 mm (.040"-.043"). I purchased my plugs from Mazda (part no. 0000-18-F287) and checking the gap with my wire gauge found all 4-plugs to be right on spec. Again, this is the part no. for the extended projected tip plug; the OEM recommended plug has a different Mazda part no. An excellent online source for our spark plugs is:
Precious metal (platinum and iridium) electrode plugs are also available for either of the above applications.
The OEM specified plug for the FS-DET (MSP) turbo engine is the NGK Laser Platinum PZFR6F-11 with a platinum center electrode and a platinum disc welded onto the ground electrode. This is an extended projected tip plug rather than the projected tip type used in the FS-DE, and one heat range colder (a 6 rather than a 5 in the plugs nomenclature). Don't substitute with a nickel alloy type here. The electrode gap is the same as above, 1.0-1.1 mm (.040"-.043").
http://ngksparkplugs.com
Proceedure
For safety, first disconnect the negative battery cable. Begin by disconnecting the low-tension wire plugs from the sockets at the ends of the coil packs and then disconnect the high-tension wires from their associated spark plugs by pulling the plug boots (not the wires) straight up. Next, to gain access to the no.2 and no. 4 cylinder spark plugs, remove the coil packs from the cam cover by removing their mounting bolts with the ratchet, 3" extension and 10 mm socket. To avoid damage because of the short length of the high-tension lead that connects the no. 3 cylinder spark plug to the coil pack, before disconnecting this lead unbolt the coil pack and pull it up while simultaneously pulling up on spark plug no. 3 lead's boot. In this way you'll prevent sharply bending the spark plug wire and possibly degrading or breaking the conductor.
After disconnecting the coil packs from their respective spark plugs and moving them out of the way, all 4-spark plugs can be removed using the ratchet, 6" extension, and the 5/8" spark plug socket. The 6" extension is required because the spark plugs are deeply recessed. All spark plug manufacturers recommend that removal of the old plugs from aluminum cylinder heads only be done when the engine is cool. Since aluminum and steel have different expansion and contraction rates, removing spark plugs from a hot cylinder head can cause damage to the threads. Upon removal, it turned out that the old plugs were Denso K16PR-U11 that, according to the FSM, are equivalent to NGK BKR5E-11 both of which are OEM specified, as stated above. After removing the old plugs, if any appreciable time goes by before installing the new ones, it's a good idea to cover the plug holes with a rag to prevent the falling in of debris.
Alternatively, to reduce the number of components that have to be dealt with at one time, the no. 2 coil pack along with the no. 1 and 3 spark plug leads can be removed, and the spark plugs for cylinder nos. 1 through 3 can be removed and replaced while leaving the no. 4 coil pack in place. Then, the no. 4 coil pack and its spark plug can be worked on separately.
Before installing the new plugs, coat the threads with Spark Plug Anti-Seize Lubricant. This will prevent binding, possible thread damage, and worst case, even stripping during subsequent plug removals. Remember, the heads are aluminum. Of course, make sure the anti-seize is placed only on the threads and not on the spark plug electrodes.
Important Note
It has recently come to my attention that spark plug manufacturers do not recommend the application of anti-seize to spark plug threads before installation. For example, NGK states that all their plugs are manufactured with a special metal shell (trivalent) plating to prevent damage to aluminum cylinder heads. Since anti-seize acts as a lubricant, applying it to the threads will cause the installer to inadvertantly over-torque the plug stretching the metal between the last thread and the seal between the cylinder head and plug. This increases the probability that the spark plug will either break during installation or upon removal. All spark plugs recommended for our engines including those from Denso and other manufacturers have this special plating and therefore should also not have anti-seize applied. For more information, go to:
http://www.wihandyman.com/forum/showthread.php?t=51691
I know many of us, myself included, have routinely been applying anti-seize at every plug change and old habits die hard. I would advise that those who want to continue this practice apply the lightest coating possible and torque the plugs to the lower end of the torque range specification to guard against overtightening. What should you do? You'll have to decide for yourselves. My belief is that provided a torque wrench is used, based on this new information and my own prior experience, either installing plugs dry or using a judicious amount of anti-seize will both yield satisfactory results. How's that for weaseling?
Proceedure Continues
When installing the plugs, insert the new plug into the spark plug socket and thread the plug into the head by turning the extension by hand until the plug is hand tight. This will help guard against cross-threading and damaging the threads as could occur if a wrench were used for the initial tightening. Once the plug is hand tight, attach the torque wrench to the extension and tighten to the FSM specification of 11-16 ft/lbs (15-22 N-m). I split the difference and tightened the plugs to 13.5 ft/lbs.
Prior to reinstalling the coil packs, coat the four mounting bolt threads with anti-seize to insure easy removal during the next spark plug change. Be careful when tightening the coil pack bolts as the FSM recommended torque setting is only 69.5-95.4 in/lbs (7.9-10.7 N-m) which works out to 6-8 ft/lbs. Since this is close to the lower limit of my torque wrench, I opted to just snug up the bolts with my ratchet. Reattach the low-tension wires to the coil packs but before connecting the high-tension leads to the spark plugs for cylinders no.1 and 3, coat the inside of the boots with Dielectric Tune-up Grease which prevents sticking and possible boot damage on subsequent removals.
Finish by reattaching the negative battery cable.
The first photo below is a view of the relevant ignition system compnents showing the two coil packs and the two spark plug wires.
The second photo is a closeup of one of the coil packs showing the low- tension connector on the left side, the high-tension lead connection on the right side, and the two mounting bolts.
The third photo shows both low-tension wire plugs disconnected from their respective coil packs. Cylinder #2 coil pack has been unbolted from the valve cover, disconnected from its spark plug, and moved out of the way. Cylinders #1 and #3 spark plug wire plug caps have also been disconnected from their respective spark plugs. These operations allow access to the spark plugs for cylinders #1, 2 and 3 for removal and replacement. The coil pack for cylinder #4 is still in place.
The final photo shows the cylinder #4 coil pack unbolted from the valve cover, disconnected from its spark plug, and moved out of the way allowing access to the spark plug for removal and replacement.
3/8" drive ratchet
Spark Plugs
Proceedure
Important Note
