Anti-drop shifter bracket. Missing the bolt, but should be easy to find at the hardware store. Just requires drilling one hole. I modified the original design with a teflon spacer to prevent metal-to-metal wear/noise. $20 shipped.
C's short shifter for 2wd BG. Super rare. Uses ball-bearings instead of bushings. Comes complete - just add grease and drop it in. Paint around ball is worn off from use, but that's normal. I actually cut it shorter and threaded the shifter knob threads further down. The rubber hose at the top was to hold up my leather shift boot. $50 shipped.
Nyloil bushings. $30 shipped for just the 4 small ones or $45 shipped with the entire shifter control rod so that you don't have to spend time grinding off the bolt to install the extra 2 bushings.
Polyurethane bushing for the extension bar. Somebody ran a group-buy for these a long time ago (Gro-Harlem maybe?). SOLD
--Ferdi
--Ferdi
