ms code error, and wont communicate
    anyone care to help , ill elaborate more if anyone responds quick
    92 protege lx-
    94 protege lx-
    onboard com port? usb to comport? battery fully charged?
      ya its chargerd. im on a serial port
      92 protege lx-
      94 protege lx-
        well what ever that was it let me in and i changed everything from 230s to 460s but no start, im cold .... and done for the today, i been outside half the day changing struts and sway bar mount bushings and some other crap....the gtr ecu is back in and warming my car up so i can head home for the night now.... ill try again after work tomarrow, it was deffinatly getting gas, it was a little loaded up from cranking..... well ms 1 /me 0....wtf...lol....
        92 protege lx-
        94 protege lx-
          so now im warmed up and home, im wondering. does ms actually control the fuel pump now? or is it just always going to run, mine stayed running while i was trying to get into ms on the laptop. another thing it never asked to select a project, is that because of the communication problem? when i actually got into ms with out that message, it was by goin to the program file 230cc no vaf/idle, with megatune closed, from the program files folder. does that mean it actually connected? i changed the settings to whats in the instructions for ms1, it says it connected or has signal or something. i think its gotta be something stupid and my brain was just to frozen from being outside all day in this 20 degree's...lol..... i feel like such a noob, im lost...lol... and ive been doing nothing but reading the megamanual, i tryed what it said to do when you get that code error message. i dunno tomarrows another day....maybe ill get lucky with the 550 map instead of an adjusted 230 map who knows....lol....
          92 protege lx-
          94 protege lx-
            You need to jump the fuel pump in the diagnostics connector. F/P and GND.
              i did, i had to listen to it run the whole time i sat there with the key on run....lol....
              92 protege lx-
              94 protege lx-
                This is one of the kits I built that was resold right?
                The megatune software needs to be installed as per instructions on the CD or the burn process of new maps may be unsuccessful.
                  i did it like 3 times, i tryed it once, then uninstalled everything, re installed same issue. im gonna mess with it after work, deadly sleeper gave me his map to try for the wue and what ever in an msq file.... im gonna try starting it warm too. it will burn the files, i can tell when i his fetch and it brings the same settings i entered up...
                  92 protege lx-
                  94 protege lx-
                    ok tried again tonight, same deal, i dont get it..lol... if i have mega tune closed and open the no vaf idle from the program folder itll half ass load and i get all the rest of the adjustments, but i get that error still and it wont connect right from the start. i cant for the life of me find any sorta driver for the serial com port. i tried it off the usb adapter after i got that driver, but nothing still, i dont get it, its gotta be something on my laptop or something i dunno...
                    its a dell c610 if anyone happens to know a serial com port driver for it
                    oh and if i use port checker itll say im connected on com 1 9600 baud and then the ms1 extra something
                    92 protege lx-
                    94 protege lx-
                      check the instructions. You have to copy over a folder. Did you do that? Also the instructions don't work for Vista.
                        ya i copy it over everytime i reinstall it unless somethings wrong with the cd . its an old dell with a serial port, i got it for the serial port for ms only , i put on xp sp3 when i put a 120 gig hd in it, i made sure all the basic stuff when i got it...
                        92 protege lx-
                        94 protege lx-
                          ok i just put everything on a flashdrive and tried the ol ladies acer using the usb adapter smoke used, and still nothing....
                          92 protege lx-
                          94 protege lx-
                            ok 3 computers wont connect, how do i tell if ms is even any good or if im wasing my time? im trying one more after work...
                            92 protege lx-
                            94 protege lx-
                              how are you trying to connect all 3 computers? all the same way?
