wheres the OBDII port located?
    hey guys i need some help on locating the port for the protege. shes got an engine light on
    03 CC LB Nissan Frontier, bunch of mods
    99 Mazda Protege (Girlfriends) bone stock
    Most ODBII ports are located next to the steering column under the dash. Not sure exactly where on a 99 Protege, but just bend over and you should be able to see it.
      Location of OBDII Port on my Car
      Photos of OBDII port (looking up at it) and access point. Port is located under instrument panel almost directly between the change holder on left and the panel seam on right, to the left of the steering column. Slide your hand under panel there and you'll feel it.
        awesome thanks guys!! im hopin its something simple, when she bought it the dealers said they couldnt find anything worng with it and couldnt get the light to shut off, im like hmmm. i just dont think they want to fixit lol. ill keep you guys posted! sorry im not on here much but i tend to chill at CF lol
          I got a 98 bj323, however I can find the obd under the panel, and someone said the early bj323 does not have obd2, only diagnostic port under hood. Is that truth?
          Thanks for answer
            Thanks for answer
            If you don't see the OBD II port than you most likely have OBD I, bridge the port under the hood and get your code! If I knew which ones you were to bridge I'll tell you but alas I do not. Best lookup how to do that sort of thing.
