After cruising through my favorite wrecking yard, I found a 92 miata 1.6 (large nose crank) and they have recently recieved a merc capri xr2 with a complete 1.6 with bouts 117k on it. Not sure as to the mileage on the miata. I understand the work involved and extra parts needed to make the miata engine work, so work aside, which engine would be a better swap for my 88 323 hb se? Opinions wanted. Thanks.
Choices
If you're going the forced-induction route, I'd grab everything I could from the Capri XR2. Then I'd have the motor rebuilt with higher compression pistons from the Miata. I haven't heard anything definitive about what year/VIN number that the Capri started using the large-nose crank, so I'd check that out first.
Hell, grab both and sell what you don't need/want.
Both bottom ends are about the same besides the slight difference in compression. The large nose miata engine would be better but will require a fwd head, oil pan and other small stuff. Turbo would be more fun though. Pretty sure that the Capri was a smalll nose crank.
Choice is yours really if u want turbo or not, both swaps will be equaly as hard cause u are either converting rwd to fwd or adding a turbo system to a car that never had one."See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by neuspeedescortthe proper spelling would be "Launchabilitiness" i do believe.
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
Easiest is just grab the xr2 drivetrain and suspension it'll bolt right into your 323. Best would be the xr2 stuff with miata short block.12 cbr250r: daily ride
01 saab 9-3: daily
98 gsxr 1100: for sale
93L: money pit/ space waster
92GL: low and slow beater
90?: the rust free shell
89LX: swapping to rust free shell
89L: for sale
89L: parts
87 conquest: dohc 4g64 swap underway
76+80 vw dashers: for sale
Originally posted by trailrider098 View PostBoth bottom ends are about the same besides the slight difference in compression. The large nose miata engine would be better but will require a fwd head, oil pan and other small stuff. Turbo would be more fun though. Pretty sure that the Capri was a smalll nose crank.
The capri changed over to the large crank mid '90 production IIRC.
The XR2 will have everything you need for turbo, grab the wire harness, ecu everything
Might also be worth grabbing the disk brake rearend too1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
Creator of the B6T Rocketchip
www.werbatfik.com
