1st Gens 1990 4WD work log
    Awesome project worklog, 5 stars for the pictures and step by step explanation.
    Threads like this one are invaluable.
      nice to see a nother awd pro.
      5 boosted bp cars,why...
        Dilbert is my co-pilot.
        As it turns out, I can't put the rear motor mount bolt in with the cross member in place. I already pulled all that sub-frame material out and am ready to do the dirty. Harness is in, mounts are all in place, half shaft is on. Everything looks hot, straight, and normal.
        Edit-Getting the cross member back in is turning out to be a bit of a challenge. I have to take a family brake right now but hope to get back at it in an hour or so.
        It looks like the speedo cable end I grabed from the Pro at the j/y is too short. I guess I need a speedo cable for a 4WD tranny. I'll take a closer look at it as soon as I get the motor mounts all secure and get the stuff back on that I had to mover for the install. So far so good.
          you should be able to lift the engine from the back hook only to tilt it enough to get it in. or try putting a jack under the front of the engine to tilt it backwards a bit
          -Steve
          94' Protege < Worklog<SOLD!
          VF10 powered!
          262 Whp & 257 Wtq
          13.1@107
          '02 Suzuki Bandit 600s
            As it turned out, when I stopped trying to get the rear bolts aligned and worked on the front mount, the rear bolts for the motor mount popped right in the holes. When the engine popped, I was like "Nooooo, YEAAAA!" Lol,
            I'm all in. I just need to tighten it all down.
            The white motor mounts came with the car. I'm using them because they were filled but I'm wishing now that I had painted them black. I might still since they're the easy ones to get to.
              that looks just.... .... .... so right. :'(
                the dirty bay makes your clean engine stand out lol..its w.e though as long as it runs that wont matter...nice pro i like it
                323 log-http://www.clubprotege.com/forum/showthread.php?t=44611
                  Why not throw in a set of AWR mounts since you're already working in the bay Jon?
                  Broke Status FTW!
                    Frankly I didn't think of it. Thanks for the suggestion.
                    I like the looks of them for sure but as far as I can tell, only one of the pair will fit. The one that fits on the rear of the 4WD tranny is different than a FWD. That was the 323 mounts I was looking at anyway and I didn't see any reference to 4WD.
                    It's funny that I didn't take a pic of that rear motor mount. I've got multiples of all the others but only one of that one. Oh well I guess.
                      I've owned this thing for a year and 15 days and am just now getting an engine into it. I'm not even close to being on the road yet.
                      (I'm a lot closer now than I was though)
                        If you can get someone to send him a rear for the 4wd, he might be able to make one up, I'm in the middle of getting the prototypes worked out for my car (as well as other BHA/BA chassis cars).
                        Broke Status FTW!
                          dangit. that turbo just looks too good sitting in there. I'm going to have to do that before ice trials start this winter. Hello, STi-Killer!!
                            I remember a while back another member put a BPT in a 4WD and said the same thing. STI Killar!
                            A week after driving it he was commenting about how heavy the car is and not much more was said about it. I don't know what happened to the car after that.
                              heavy??? naaah!
                              Last winter, I drove the blue car in ice trials with the stock B8 SOHC, on bolted tires. At one event, I actually took FTD! (it was a night event, I had awesome lights, and the ~600whp sti didn't show up. But I did it!)
                              Now, If I exchange that 103hp (at the crank when new) motor with a BP DOHC turbo motor (173.3fwhp on the dyno, in my wagon), I'm only gonna weigh maybe another 30 lbs max, including turbo/exhaust/intercooler/piping. Now translate that over to the fully gutted (subtract ~300 lbs) protege that I got from Craig in Montana. Then add in a slight turbo upgrade, and a mazdaspeed motorsports clutch-type rear LSD....
                              maybe not sti "killer". I could settle with "obliterator" or "decimator" or even just "maker of mincemeat"...
                                Originally posted by SgtRauksauff View Post
                                heavy??? naaah!
                                Awesome!! I'm really glad to see you taking the Protege in the direction I wanted to go. A little sad for me, a lot of glad for you!
                                Regards,
                                Joel
                                1988 323 GTX - Heavily modified
                                DJT Motorsports (Oak Park, MI) - like no other
