This factory manual for the FS-DE engine contains ~ 50 pages and is divided into two main sections: General Information and Engine. The part number is: 9999-95-193D-98. The layout is as follows:
General Information
How To Use This Manual
Units
SAE Standards
Fundamental Proceedures
Electrical Systems
Abbreviations
Engine
Mechanical
Engine Overhaul Service Warning
Engine Mounting/Dismounting
Engine Disassembly/Assembly
Engine Inspection/Repair
Lubrication
Oil Pump Disassembly/Assembly
Oil Pump Inspection
Technical Data
Service Tools
I obtained my manual from Montgomery Mazda:
http://www.onlinemazdaparts.com
The cost was US $30.00 and shipping was free. The service was extremely prompt - I received my manual one day after it was ordered. Even if you're not planning to rebuild an engine, the information contained here is worth acquiring. Montgomery Mazda apparently no longer sells the manual and I don't know about its availability generally from other dealers. To obtain a copy it might be necessary to search online. E-Bay is often a good source for automotive manuals.
All FS-DE engines (2001-2003) are covered as supplied in the sedan, MP3, and P5. Since the basic engines are the same, the manual can also be used for the FS-DET (turbo) engine.
The manual covers removal of the engine from the car and complete disassembly, inspection, repair and reassembly of the head, block and internal components of all FS engines. Operations such as removing motor mounts and the description of the layout of all vacuum lines are not covered. For this information, as well as removal and replacement of such things as the intake and exhaust manifolds and all engine accessories, you need to consult the FSM.
Finally, according to TheMAN's FAQ, The FS Engine Manual can also be used to rebuild the FP-DE 1.8 L engine. As TheMAN explains it, the FP is essentially a destroked version of the FS with all specifications the same except for the connecting rod length, center-to-center distance, (129.2 mm; 5.087") and the intake camshaft lobe height (43.0062 mm; 1.6931").
Happy Motoring!
General Information
Units
SAE Standards
Electrical Systems
Abbreviations
Engine
Mechanical
Lubrication
Oil Pump Inspection
Technical Data
Service Tools
Happy Motoring!
