Results 1 to 12 of 12
Thread: Fuel Pressure Regulator Control solenoid Valve (GTR)
  1. #1
    Registered User
    Join Date
    Sep 2009
    Location
    Fort McMurray
    Posts
    67
    Feedback Score
    1 (100%)
    My Question is What is the purpose of this Fuel pressure regulator Control Solenoid Valve. It's mounted on the side of the engine behind the distributor. Mine is missing and almost ready to install my 1.8L BPT GTR engine into my MX3. Would i be able to eliminate it by just connecting the two vacuum lines together so the fuel pressure regulator sees full vacuum all the time? Or Can i get a solenoid valve from another mazda model thats easier to get then a GTR one.
  2. #2
    Registered User mazdasly75's Avatar
    Join Date
    Mar 2009
    Location
    Trois-Rivières, qc
    Posts
    392
    Feedback Score
    3 (100%)
    This valve was meant to help restarting a hot engine. It raise the fuel pressure for an amount of time, when restarting, to enrich the fuel mixture. The GTR engine is some kind of low compression ratio (8.2:1) and if you're using a high octane grade fueling, it's more resistant to pressure and firing.
    You can disable it, the worst it could do is to take 3-4 sec. before starting. There's 2 kinds of fuel pressure regulators. First is a 2 nipples vacuum that I mostly saw on 92 GT-R and the second is a one nipple vacuum like the one I got on my 93 GT-R familia.
    I removed mine when I installed MS.
    If you want to disable the check engine light, open the ECU (whatever the one you got) and cut "1E" contact, this will make your light to never go on.
    Hope this help
    -1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
    -2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
    -2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
  3. #3
    Megasquirt and Turbo Guru Lex's Avatar
    Join Date
    Dec 2004
    Location
    Vancouver, Canada
    Posts
    7,205
    Feedback Score
    16 (100%)
    ^ This is correct. I'd like to add that it is not just for starting the motor but also for idling and low load conditions when the motor is heatsoaked and has been restarted. The intake air temp sensor (IAT) reads artificially high when the engine has been shut off and restarted a short time after due to the high underhood temps and no airflow around the sensor. This causes the ECM to deliver less fuel causing the engine to run too lean until enough air passes around the IAT to bring it down to normal temperatures. So, the ECU uses this solenoid to allow the FP regulator to see atmospheric pressure instead of vacuum pressure increasing fuel pressure to overcome the momentary lean conditions on a hot restart.
  4. #4
    Riel Performance Parts therieldeal's Avatar
    Join Date
    Oct 2005
    Location
    Northeastern CT
    Posts
    11,766
    Feedback Score
    27 (100%)
    i ditched mine from day one, and have never had a problem
  5. #5
    Registered User
    Join Date
    Sep 2009
    Location
    Fort McMurray
    Posts
    67
    Feedback Score
    1 (100%)
    Can someone post a picture of the two different styles. In the service manual it talks about a low temp and a high temp solenoid. Were as by the looks of my engine should only have one. If i did decide to install one any idea were i could get one.
  6. #6
    Join Date
    Oct 2005
    Location
    Northeastern CT
    Posts
    11,766
    Feedback Score
    27 (100%)
    the service manual is describing the 2 port style which i have never seen an example of in real life.
  7. #7
    One of a kind. DeeAOne's Avatar
    Join Date
    Apr 2009
    Location
    Warner Robins, GA
    Posts
    2,025
    Feedback Score
    4 (100%)
    i dont have this hooked up on my car either. its does take a little longer to start but other than that i dont notice any major drawbacks.
    heres one on the KL.
    '88 323 sedan, K-swapped..
  8. #8
    Registered User
    Join Date
    Sep 2009
    Location
    Fort McMurray
    Posts
    67
    Feedback Score
    1 (100%)
    To eliminate it do i just connect both vacuum lines together so the fuel pressure regulator see full vacuum all the time? Or does someone have one for sale?
  9. #9
    Join Date
    Mar 2009
    Location
    Trois-Rivières, qc
    Posts
    392
    Feedback Score
    3 (100%)
    ya just plug a vacuum to the regulator.
  10. #10
    Registered User
    Join Date
    Jul 2005
    Location
    Northern VA (Woodbridge)
    Posts
    289
    Feedback Score
    0
    I now have an Escort GT. It recently stranded me on the highway. I am getting a code 25 for this valve.
    I notice that the valve's 2 prong wiring harness is disconnected. I would guess that this was done by the previous owner.
    The car won't presently start and I am trying to rule this out as the cause.
    If everything else was connected besides this harness, would the car still start?
    I think it should. I reconnected it and it made no difference...the car still wouldn't start.
    Any ideas?
    Thanks!
  11. #11
    Registered User bomdoutscort's Avatar
    Join Date
    Aug 2005
    Location
    Cincinnati, Ohio
    Posts
    3,148
    Feedback Score
    8 (100%)
    Quote Originally Posted by dx92beater View Post
    Any ideas?
    Thanks!
    You need to start a new thread in the escort section and also check your timing belt.
    "Who Dey"
  12. #12
    Registered User
    Join Date
    Jul 2005
    Location
    Posts
    289
    Feedback Score
    0
    Quote Originally Posted by bomdoutscort View Post
    That's ok, this will do. I really don't think that there is any difference in location between the protege and escort as far as the timing belt per the FSM. I'll also check my timing belt.
    93 EGT 5M, Bimini Blue
    132k miles, DD only
    0w20, EG Fram Oil Filter for Probe 2.5L, Magnetic Drain Plug, ebay cone filter, 03 Protege Rotors, moog sway bar end-links on rear sway bar, mx3 seats, Power Sunroof, Miata Valve Cover Bolts, Gatorback Belts, Timing *14 on 87 Oct, Autolite 3924 @ .043 - 35 mpg at 67 mph (95% highway driving) with A/C and headlights on. Untested for fuel economy: Sylvania EcoBright 9004, .717 5th gear with D6 ATF, NGK wires, 195/65/15 Kumho LRR 4 wire tps
    Former Car: 92 Protege DX 5 spd.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Fuel Pressure Regulator
    By Eric in forum Engine/Drivetrain - BHA Chassis
    Last Post: 10-31-2009, 12:30 AM
  2. Fuel Pressure Regulator
    By reddragonmazda in forum Engine/Drivetrain - BG Chassis
    Last Post: 03-31-2008, 10:10 PM
  3. pressure regulator valve-importance?
    By Kitty in forum General Discussion - BG Chassis
    Last Post: 03-01-2008, 11:57 AM
  4. Fuel pressure regulator?
    By projectmx in forum Engine/Drivetrain - BG Chassis
    Last Post: 10-14-2006, 07:15 PM
  5. Fuel pressure regulator
    By P-rotege in forum Engine/Drivetrain - BG Chassis
    Last Post: 04-13-2005, 01:10 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
