newb buying a gtx
    Originally posted by 808 View Post
    NA is not stronger. The block is the same but the GTX rods are way stronger and NLA. The manifolds will bolt up to a 1.6 but not a 1.8. I can't tell you how much of a vast difference the 1.8L swap makes though.
    how would i do a 1.8 swap and keep it boosted though if the manis wont bolt up?
      It's buying a BPT and swapping the whole thing... There's a write up here somewhere i think...
      1988 White GTX - #1 parts
      1988 White GTX - #5 Rally car
        bpt didnt really come in any cars in the states though right? all i have seen those for is like 1500 which i dont want to spend. what about the probe gt 2.2l turbo?
          2.2L swap would probably cost you the same in customization. Seriously if you aren't gonna go BPT stay B6T. you can use a non-turbo lower end.. it should be fine. unless you're pushing tons of boost.
            2.2 swap to bf awd trans=nonexistent bellhousing adapter plate and almost immediate busted trans. Unless I'm seriously deluded there wasn't a 4wd option on that 2.2 block. Cuz if there was, then I've been REAL stoopid trying to get power outta the bpt..
            though I reckon it woulnd't be the first time
              i guess i need to get in there and see exactly what happened to my motor. if i do end up just replacing the bottom end i could use any 1.6 from say a miata or something? the bottom end on the cars outside of the gtx are weaker though arent they?
              i would use another bpt or b6t or bpd if i could find one...
              whats the best thing for me to do?
                You can get a new Miata B6 short block here for a very good price. Or you can get a Topline Major engine kit for the B6 for about $200-300 depending on where you get it. If your block is not damaged that would be the way to go.
                  i can pull one from a junkyard for $300. all i saw on that site was 1000-1500
                    Well you can always roll the dice on a wrecker engine. I prefer to know what I'm getting. $1000 + $140 shipping with no core for a recon shortbock is very reasonable. If your block is good rebuilding your existing block with a rebuild kit for a few hundred dollars is also very preferable to buying a junk yard engine in my opinion.
                      yea. i will hopefully be able to just get by with a rebuild kit.
                        what about usin an escort gt motor?
                          hopefully an escort motor will work i am lookin to buy one now? could i also use the intake mani and head? i have some suby legacy ihi turbos for sale also...
                            Yes it will. It will be a bp instead of a b6 though.. so you'd have to use the EGT head and find the turbo parts for a BPT.
                              whats it matter that its a bp instead of a b6? i will have to use the escort head and im guessing my manifolds wont bolt up to that then and thats why you say i will have to find turbo parts? where will i find those? and that is including exhaust mani? turbo? intake mani? hmmm i wonder if its worth it for me to do. i got the escort today but i was hoping to use my manifolds.
                                none of your manifolds will fit.. Corksport has manifolds i think.. the turbo can be harder to find.
