Jeffs MSP GTR Build
    The same numbers can be done with a BP hydraulic lifters CH!? Well, I guess you will have braggin VVT rights.
    It would be good to state the combo used, psi, if all accessories installed, etc on that dyno chart.
    No wonder with the Apex having it max out in the plus side gave me that nice punch.
      nice man glad you brought your build over to CP, i was checking out on toprotege.com and all is looking good!
      i'm super excited for the vvt and the numbers you're going to lay down!!!
        Great information, nice number. This is very helpful! though 250whp isn't high boost, this is about 14psi on a VJ23 wich is the stock wastegate setting. The high EGT appear abut 20-22psi, so this where I would start the water spray.
        Simple cam tuning rules for turbo engines:
        Advance intake and/or exhaust => more low-RPM power, less high-RPM power
        Retard intake and/or exhaust => more high-RPM power, less low-RPM power
        Less overlap=> lower EGTs, faster turbo spool, less fuel
        More overlap => higher EGTs, slower turbo spool, more fuel
        And according to this dyno plot, the full advance is 6 degrees and the full retard is 12 degrees.
        -1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
        -2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
        -2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
          good info there.
            should be interesting to see what happens to therieldeals setup once he retards the intake cam.
              Hopefully not a "zoom zoom boom" !
              I'll probably retard the cam and tune everything like I normally would, then I'll go to the dyno and do a pull with it. Then shut it down, advance the cam timing, and see how much power I lose. I haven’t gotten a good dyno pull yet with the new cams, the 320hp/325tq was with stock BPT cams (low-lift intake cam).
                does anyone have information on the pwm signal that is sent? I dont have a 2001+ manual so I have no idea what it should be outputting at idle or full retard.
                somebody please get me the info I think I figured out a simple solution that takes a normal DC voltage in and can output whatever pwm frequency we need based on the voltage input, just need the specifics so i can get back to my buddy and we will try to put one together.
                  i feel like someone on Miataturbo figured it out and was using the MS open loop boost control table to control it. try searching around over there?
                    oops posted here by accident
                      Unless you are drag racing, more than 18 psi is silly to have on a daily driven car.
                      One thing is what they do, lets see your setup...
                      Take it easy my friend, dont let this get over your head, it is just a car!
                        most interesting thread so far. anyone else notice the first red/green graph has a similar cross over to that of a VICS.
                        to have absolute control of cam timing could open countless doors for our community.
                          Subscribed
                            PS: Intake cam retarded 12* resulted in ~10% increase in VE from ~5000rpm+
                              OK but is there any drop in your VE below that mark? I'm about to do some test too in June. Let me know.
                                any updates?
