my first klze 2.5 swap
    i need advise about a part that i bought today. i got the mx3 subframe for my 323 the question is should i need to get the sus and caliper diskbreak and everything that holding in order to put a klze engine
    all u need is the crossmember and mounts and the lower control arms, everything else works.
    1992 MX-3 GS - KLZE
    1997 Probe GT
    Its not a BP05.... Its a BPOS... BIG PIECE OF ****
      ok so this means that the mazda 323 spindle will work on mx3 subframe? or i should get the mx3 spindle
        no the spindle should work no problem
        its jsut a lot easier to swap in the front subframe
        1996 V6 Escort
        1993 escort wagon DE/ZE hyrbid, ported heads, 5 lbs
          yea if you use the 323 spindles you'll be stuck with the smaller brakes...upgrade the spindles so you can run the larger rotor/pad/caliper bracket combo
          any Qs just send me a PM.
            ohhh ok brossss im going to the junker and pick the spindles up because a let them on the floor went i was trying to remove the front end. BRB lol
              haha ok good luck! hot there today?
                this is some pictures from today when i came back from the junker...
                those are my friends at work... the guy fighting with the snake what happen is he love mustang cobra, the one in the floor he is always drunk lol
                i might go for KLDE with mods. i will make port and polish to the klde and i am pretty sure that i can reach the same hp as a ze and still have lo compression to boost more psi in turbos
                  hot as hell and raining whole day but i went to the junker anyways
                    Damn I miss O town Damn rusty ass northern cars. Nice score on parts. I may pull the whole subframe and lcas for my swap. Just easier
                      should have brought the rack too if you are going to run power steering. the 323 uses different fittings at the rack. at least mine were different
                        how do i know if my rack will work or i need the mx3 one.. i am confused
