Results 1 to 4 of 4
Thread: need help damaged piston / head look at the pics
  1. #1
    Registered User mazdasly323's Avatar
    Join Date
    Jun 2008
    Location
    Alberta
    Posts
    27
    Feedback Score
    0
    Angry need help damaged piston / head look at the pics
    Hi I'm doing the headgasket job on my BP. And I need some advice before the re-assembling When I lifted the head I notice that on the piston #4 there's some small dent on top like if somebody punched it with a flat screwdriver or so. and on the head side too . wondering what to do with that . Anybody knows if I can run with a piston like that or not. and maybe dumb question but what all the black means ...too rich or too lean
    the block
    Zoom on piston #4 (look on top and bottom of the piston)
    on the head
    MAZDA 323 BP TURBO
    SEE MY CARDOMAIN PAGE
  2. #2
    Likes AWD a bit too much jay's Avatar
    Join Date
    Jan 2006
    Location
    Snohomish, WA
    Posts
    4,198
    Feedback Score
    7 (100%)
    That's asking for ping and detonation and bad stuff. Looks like something got in there and rattled around for a bit. Take a good hard look at that plug, see if some ceramic came off the center electrode. Maybe a light application of emery paper would help smooth those scars out. Use a shop vac while doing this, and go lightly. What's the bore look like?
    Might be running just a tad rich. You also wanna take a good look in the ports on that cyl, make sure there's no damage there either. Prolly wanna compress the valve springs so you can take a peek at the seats as well.
    http://www.clubprotege.com/forum/vbp...?do=view&g=110
  3. #3
    Registered User
    Join Date
    Jun 2010
    Location
    Australia
    Posts
    55
    Feedback Score
    0
    I have the same problem with my BPT, part of the spark plug electrode snapped off and dimpled the piston, scraped the bore but no head damage. It was running rich on high boost (previous owner had thrashed it) so it could have detonation
  4. #4
    Registered User
    Join Date
    Apr 2008
    Location
    BC
    Posts
    1,302
    Feedback Score
    2 (100%)
    Head you could most likely get resurfaced and it should be good to use.. Piston shows some damage.. I might consider reusing it again.. If it wasn't boosted I wouldn't have a problem with reusing it.. But with boost thats up to you..
    Have a really good look at your valves, especially your exhaust valves.. make sure they aren't bent and there is no damage to the seats.. what ever caused the marks would have exited out your exhaust valves..
Thread Information
Users Browsing this Thread
Similar Threads
  1. KIA Head & Piston ??????
    By scort4life in forum Kia Sephia
    Last Post: 07-23-2009, 09:29 PM
  2. Winter project (piston ,ring , tranny, head work)
    By Protégé17psi in forum Engine/Drivetrain - BG Chassis
    Last Post: 10-27-2008, 12:46 PM
  3. new pics with new head lights and hood !!!! 305
    By jraz305 in forum Exterior/Interior - BG Chassis
    Last Post: 10-24-2007, 08:54 PM
  4. cylinder head pics
    By ben in forum Test Forum
    Last Post: 12-19-2006, 06:15 PM
  5. B8: piston to head clearance
    By JesseSays in forum Engine/Drivetrain - BG Chassis
    Last Post: 12-09-2004, 06:05 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
