Yes! mx-3_4evr is finally turbo!
    I'm doing a complete build here is what I got:
    BLOCK
    -Reconditoned crankshaft
    -ACL RACE bearings (.010 main and rods)
    -New shimmed oil pump w/ boundry engineering gears
    -B6T rods
    -Top line OEM pistons (9:1 cr)
    -ARP main studs
    HEAD
    -Mild port and polish
    -BP05 cams (looking for some turbo ones)
    -OBX cam gears
    -ARP head studs
    -Supra turbo PCV
    INTAKE
    -GTR intake manifold
    -4 wire TPS & throttle
    -OEM VJ20 intake pipe
    -FMI
    -Top fuel 1000 BOV
    FUEL
    -460cc injectors
    TURBO
    -VJ20 exhaust manifold
    -VJ20 turbo
    -VJ20 o2 housing
    GAUGES (all made by innovate)
    -oil pressure
    -Boost
    -A/F ratio
    More to come.......
    Idk who is worse you or chris?
    -Steve
    94' Protege < Worklog<SOLD!
    VF10 powered!
    262 Whp & 257 Wtq
    13.1@107
    '02 Suzuki Bandit 600s
      Chris is worse! I actually intall the parts and run it for a little bit untill my engine breaks because of something really stupid
        new crank + .10 over/ under bearings ... i assume you ment you are having the crank turned new would be to oem spec no ?
          ^ yes. It's my old crank but it has been polished again
            Why not run the itbs and make a custom plenum and have turbo and itbs?
            SPI swapped
            http://www.cardomain.com/id/WhiteLightning96
                lets see how long this lasts..anyone taking any bets?
                '88 323 sedan, K-swapped..
                  I bet I keep it turbo... would adding a VF12 be a change?
                    Ditch the puny VJ20 and run a Holset. Trust me on this
                    92 240SX: KA/T25, nerd mobile
                      cool man, glad to see you've almost got everything.
                      hope things go smoothly!
                        Finally on the bandwagon lol.
                        "Who Dey"
                          ^yes^
                          Why not?
                          But G/L on this one all the same
                          Powered by ACME
                            vj20 with 460's noice lol
                            http://www.wihandyman.com/forum/showthread.php?t=47653
                            my fs thread
                              Today I worked on the GTR manifold. I ported and polshed it, as well as port matched it. Tomorrow I'm planning to finsh the manifold with some nice stuff
