Greetings,
I just got a 1997 Protege in good shape. One of the issues I am having is the fan on the condenser won't run. When I switch on the AC the driver's side fan comes on and stays on. The original fan on the passenger side I had to replace because the motor was rusty and the fan looked like someone melted it. The replacement fan will work if I hook it directly to the battery, but, apparently something is amiss.
I printed out some electrical circuits for the fans/AC system and it appears to me there are two relays for the fans (one for each). Is this true, or, does the big blue fan relay control both?
Like I said...getting no power at the electrical connector but the fan has been confirmed to work when power is directly fed to it.
Relay I'm not seeing? Fuse? Or some part of the AC circuit I'm not seeing?
TIA, I appreciate any help as it's hot and miserable and the AC isn't working well at idle because of this.
________
Buy no2 vaporizer
________
Buy no2 vaporizer
