While I'm at it, if you live where rust thrives, you will most probably end up with towers that look like the pics down below. I'm obsessed with rust...I hate it...
As you can see the problem doesn't only show up on the top face of the strut tower, but also going up the rear pillars hidden under the firewall
This weekend I cut those towers from the parts car and will be using them as templates to make new tops and edges that will retrofit on top of the existing towers. They will go high enough up the side allowing you to clean that area up as well as you will see... I have so much shyt going on right now that this will fall under the urgent but not important category; so it may take a few weeks before I get my first one built.
Moderator you can chuck this in suspension should you see fit...
