    Originally posted by Loco_R View Post
    if i see something that did not used to happen, like smoke or oil from the valve cover, i will think something is wrong! it was fine and now it is not!
    lol same thing i thought but i also thought it might be a easy fix with a catch can but like always i was wrong and it was something else the learning curve of life lol.
    well when i took off the exhaust mani i found my exhaust leak their was a spacer between th exhasst mani and the gasket
    stupid me
    when i took off the ehxaust mani gasket i found out that cylinder 3 that the compression was at 90 well the gasket hole for that cylinder was burnt or vaporized 1-2 layer of gaskets for the exhaust mani and was wondering if that would be the reason why the compression would be low for that cylinder ???
    and mayb if i was lucky that the piston rings might be still good????
    also on a side note when i pulled the plug for number 2 piston it was steaming / smoking any idea y???
    also i found out what was causeing the smoke the downpipe had oil in it and i guess was burnning it off ,also my fmic had oil in it too any idea if that means the oil seals on the turbo are gone??
    also was wondering if i just replaced the exhaust mani gasket if that would fix my compression problem and if i got the oil seals for the turbo and mayb the turbo rebuilt if that would fix the oil being dumped into my downpipe and the oil being pushed into my fmic and blowby ???
    any help or opinnions would be apreciated
    mike
      the exhaust manifold gasket wouldn't be the cause of low compression. The valve seals it off before it gets there.
      -Steve
      94' Protege < Worklog<SOLD!
      VF10 powered!
      262 Whp & 257 Wtq
      13.1@107
      '02 Suzuki Bandit 600s
        aight thanx ace for the info
          Did you do a leak down test by chance?
          unless you put a hole in a piston id lean towards burnt valve(s)
          -Turbo Mx-3
            nope no leak down test but after inspecting the valves i noticed piston/cylnder 3 valve was all black as the rest were gray so mayb valve seals still doing some work but heres some pixs
              MACRO FOCUS!!!!!!!!
              take apart the center from the hotside
              & take off the compressor cover
              did you have anything from the valve cover to the intake side of the turbo?????
              anything @ all????
              are any of your ports wet with oil?
                Originally posted by bpt323 View Post
                MACRO FOCUS!!!!!!!!
                anything @ all????
                ok will take apart turbo here in a couple minutes and will work with the focus lol damn auto focus and from the vaf to the turbo their was no oil and as ports u mean exhaust ports???
                  yes, exhaust ports
                    here ya go bud
                      heres some quick pics of turbo internals
                          ight monday or tuesday will be sending the turbo off to the shop to get rebuilt and also to get a bigger coldside turbine installed also will be taking the head to the shop to get looked over and mayb a valvejob done too
                          wish me luck guys
                            just cause i forgot to take pixs last nite
                              turbo fried???
                              great to see people now days full of optimism!
                              That will explain the low compresion on the cilinders, yeah right it is the turbo!
                                lol ok well turbo is at the repair shop and i just got back my head from the shop got a valve job done and a port n polish had to skipp on my orignal head plans for now
                                ill call the turbo place tomrorow and see how long for the rebuild to be done on the turbo etc
                                will start re assembling everything here in the next couple days with a few extra goodies
