Hi,
I have a '94 Protege with 1.8 DOHC, Auto F4EAT reans that started the "pop"out of gear. When the trans is cold it does not shift. After trans warms up it functions normaly. Trans has 90K as it was replaced 5 years ago with a rebuilt unit from Certified Transmission.
I pulled DTC's and noticed #6 - Vehicle Speed Sensor was set. What does this DTC mean and where is the VSS located?
Prior to all this fun that I am having I replaced the upper trans motor mount (the one unf=der the battery). I pressure wshed the gunk off the trans and am wondering if this has something to do with the DTC & poor shifting when cold??
Thanks for all the help.
