yeaaa chk this out!!
    lol... this reminds me of my friends truck... he has a twin turbo cummins that has a about 850hp on the "race" setting lol... but he was ripping down a road one day and guns it, it hits about 70psi of boost (normal psi lol...) aand the exhaust wheel explodes and sends about a million bits all over the road... nothing sounds like a 97MM exhaust wheel flying out of a 5 inch pipe lol...
      b6t, thats actually a common problem on them trucks, i found a guy on craigslist with 3 he was trying to sell with snapped shafts, but his price was super high.... im not sure if its just the first hx35s or all but im not scared im not running over 25-30 when i use it...
      92 protege lx-
      94 protege lx-
        im deff going to a t3 but not sure what one yet!
        My baby 93' Protege Lx--R.I.P
        New Baby 94' Protege Lx Black
        91' Miata - SOLD
        93' Protege LX new Project (no rust)!
        Mods: Protege:
        Engine: Fully built with wiseco 9:1 +1mm ceramic coated tops and molly skirts, M-tuned H beams, ACL Race rod and thrust bearings with King Mains, Arp Mains ,rod and head studs,3 lbs lightend crank, Everything is ballanced, spec stage 3 clutch,lightend flywheel, RX7 Afm, Fidanza Adj. cam gears, timing,Cut intake manifold from BPT323, exintake cam swap,full port and polished head 1mm stainless oversize valves, vf12/vj20Turbo, 3" custom full exhaust w/external wastegate,3" E-Cut, Eclipse crushed BOV , Fmic, Aem Urgo wideband, Autometer boost gauge, Magnaflo Muffler,batt relocated to trunk, slight wire tuck with engine bay fuse box under dash Bp26 ecu
        Suspension: Energy Suspension rear trailing arms,Es Front Sway bar endlinks,Zx2 Front Sway Bar,El Sport w/bilstein mono tube struts and don't know what springs, Suspension Tequniques Rear Sway bar with Es endlinks,mx3 rear lower tie bar. corksport SS brakelines and clutch line.
        Exterior: Adler Racing 16"s ,Mx6 Front lip,EGT Glass Sunroof,Edm Headlight & corners EGT side skirts,Gt Led wing, Led interior 3rd brake light
        Audio: few things polk momo 6.5 components, VW Monsoon Front Componants with monsoon amp,alpine head unit
          no he blew up the BIG turbo... the hx35 is tiny compaired to this one...
          here is a pic of the one he blew up... its the one on the far right, the one in the middle right is a hx35 and the middle left one is a t3 t04e 57trim (the one going on my car :D the far right one is going on a buel powerd chopper...
            he has the twin of those big turbo on cummins?
            swapping into another shell!
              twins are common on them, ive also heard of people running 3 turbos on them too... but ya that things a beast, even the holset doesnt really look too small next to it, the first 2 look sorta smallish tho...
              92 protege lx-
              94 protege lx-
                never seen anyone with twins in my life lol besides on youtbe
