**Moderators please advise if photos with name sheet still needed.**
PHOTOS HERE - http://www.wihandyman.com/forum/show...&postcount=264
Selling my oil filter relocation and front mount cooler setup from the 323 since I won't be supercharging the car.
2,000 miles of use and 3 oil changes on the entire setup.
This is for 2.5L KL engines, can be adapted to just about anything with a bit of work - you'd need an engine specific adapter plate at the block.
Included in the kit are (details for everything below):
In parentheses are the prices for each item.
*adapter plate by MBX
*XRP adapters, fittings, and hose ends
*XRP lite braided black hose
*mylar fyre-foil heat shield sleeves
*Maximum Motorsports oil filter relocation housing
*Earl's front mount Oil Cooler 3" x 8.25" x 2"
MBX adapter plate
XRP adapters, fittings and hose ends
XR-31 Black -8AN hose & heat shielding
Earl's front-mount oil cooler($87)
Maximum Motorsports remote oil filter mount ($50)
So, as you can see, I have $447 + tax + shipping (over $500 in all) invested in the whole thing, plus many hours of sizing everything up and getting all the right parts put together. I don't expect to make it back, but I won't sell it for $120.
$385 shipped
Shipping to Canada extra, as usual.
MBX adapter plate
- standard issue, mounts with 3 stock bolts, comes with 1/2" NPT threads ($45)
- (1) forged 1/2" NPT to -8AN male adapter ($17)
- (1) straight -8AN hose ends ($12)
- (3) 90-degree -8AN swivel hose ends ($75)
- (1) 30-degree -8AN swivel hose end ($30)
- (1) straight -8AN female-to-male take-off adapter with integrated 1/8" NPT gauge or sender port - this thing is cool because you can put either a gauge or an oil press/temp sender inline without extra fuss ($16)
- (1) 90-degree, 1/2" NPT male to -8AN hose end ($35)
- (2) straight 3/4" NPT to -8AN o-ringed boss adapters ($22)
- ~5 feet of it. Costs $0.67/inch.
- Originally posted by xrp
- Originally posted by Earl's
- Remote Filter Mount, Anodized Billet Aluminum, Straight Port
- Uses massive mustang 5.0 filter (79-95) for minimal pressure drop across filter
$385 shipped
