Welding Projects Inside
    Well i saw this section so i thought i would post up some of my fab work!
    Sean
    1988 Mazda 323 gtx
    1.8 bp-t swap
    cool, i need a tig...
    92 protege lx-
    94 protege lx-
      what rig are u using?
        pretty good welds
          Ya the stainless welds are underfilled, and have a nice pinhole. I like aluminum better. I am running a Miller Syncrowave 250 with water cooler
          Sean
          1988 Mazda 323 gtx
          1.8 bp-t swap
            Here are some better pics of the aluminum bead
            Sean
            1988 Mazda 323 gtx
            1.8 bp-t swap
              Very nice beads. How long have you been tig'ing to get as good as you are now? Definitely like that you're back-purging the stainless.
              --Ferdi
                man your welding sucks lol. You really make some nice beads, the welds on that rad really look great. nice work
                  friend, when i grow up i want to weld just like you. very talented.
                    Beautiful!!
                      I started mig when i was 15 or so, I am 25 now. I have taken welding school and have worked as a boat builder and in a couple welding shops. Most of my tig welding experience has been just welding at home though. Thanks for the props!
                      Sean
                      1988 Mazda 323 gtx
                      1.8 bp-t swap
                        Good stuff
                          Very nice - are you offering this as a service to CP members?
                            Ya I would be happy to. I do have free time to weld on the weekends.
                            Sean
                            1988 Mazda 323 gtx
                            1.8 bp-t swap
                              thats some really good work... man i have a long way to go .just started to try my hand at welding ...
