My 626 mtx swap.
    My 626 mtx swap.
    Decided i'm going to document this lol, take some pics along the way. I'm going to borrow my parents camera they just had fixed since i can't find parts for mine anymore lol.
    Anyways, the car.
    It's a 1993 Mazda 626 ES, automatic, dark green.
    Here's an older pic of the car after i bought the original mtx 626 parts car for the swap, but i had to get the car on the road sooner than i thought, so i just parted it out due to lack of space.
    Here's some pics from a couple months ago, things have changed since that pic lol, slammed 3" on kybs & vogtland springs, 97 626 ES rims, yellow fogs and a crap load of parts lol...
    So expect some updates, hopefully at least once a week lol, i plan on driving it up the car ramp so i can use my electric impact on a few things before the car gets dissabled lol...f u horizontal crossmember...lol
    Also the reason I'm doing the mtx swap now is because the auto transmission is failing quickly, it's only good for short trips into town, nothing above 80km/h lol, 3rd gear slips bad if you give it more than about 10% throttle...argh..
      Sub'd
        so i'm e-testing our 97 Olds Cutlass sedan, and if it passes then i'm doing the front left wheel bearing so i can drive this during the conversion, til then i'm using the car locally lol so i can't get parts (wreckers 45 mins away) til the Olds is solid.
        Before I disable the 626 for the swap i'm going to drive it on the car ramps I have so I can easily work on the underside...then push it off when i'm done under there...lol.
        I plan on sourcing the parts at the wreckers thats 45mins away instead of from the guy in Toronto (90-100mins away). They always give me good prices, so i'll see what I can get for $100 right now...at least the pedal assembly and clutch master cyl so I can install those right away.
          To bad you didn't decide to do this just a month earlier. I had a practically new exedy pp and disk and a mx3 fly. Sold it cheap
            wow man. i have the twin to your car pretty much. same color but mine is a 97. and already a mtx kl.
            ~PaTricK~
            -Current car's-
            What are you driving?
              yea i remember you saying you were going to pick one up! post some pics of it.
              So tomorrow (monday) i plan on heading to my friends wreckers to pull the pedal assembly and clutch master cylinder, hopefully the mounts i need so i can fill them, and maybe the linkage so i can make my DIY shifter fit properly.
                ive only had it about a month so far. but i did swap a full leather into it already. used 2nd gen MX6LS leathers in the front, and a set of 626 leathers for the rear. i also already installed the JDM stainless steel door sills which are hella rare. gonna wait till after winter to do any suspension though. no reason to do it right before winter hits.
                ~PaTricK~
                -Current car's-
                  ^makes me want a 626 even more now
                    nice looks sharp!
                    well today i went to the wreckers, they had slim pickings but i managed to get
                    mtx kl starter
                    shifter and linkage
                    clutch pedal
                    clutch master cyl
                    brake pedal
                    clutch master to slave line w/ flex hose
                    so i can modify the linkage to fit the shifter i just fab'd up, but everything seems in good shape, just needs a good cleaning. pics will come after things are cleaned up lol.
                    i'm going to go back either tomorrow or weds to get the mounts, and pull the trans & store it somewhere til i can afford it lol.
                    also i'm going to buy a new clutch slave and a maybe an overhaul kit for the clutch master, and then after i pay for the trans next pay i'll order the clutch for the pay after that lol...so only a month!
                      Sub'n :D
                      1988 323 GT - B6T Powered
                        well today was an exhausting day lol, went back to the wreckers and decided "hey instead of just grabbing the other mounts, i'll take the trans too"
                        So i managed to drop the engine and trans out of the mx-6 lol, what i job that was....y pipe, axles, everything, car was complete minus the alt (SOB!) and intake piping lol. Also it was stacked on top of another car! Oh well haha.
                        Anyways, the trans with the flywheel and the mounts will cost me $120, so i'm going back on the 17th to grab it all.
                        $50 first load
                        $120 second load
                        $120 clutch
                        $50? flywheel machining
                        $40 clutch slave cyl
                        $50 misc fluids, seals
                        So shouldn't cost TOO much in the end to do this...hopefully lol.
                          Good score. Not too bad to do a mtx swap. Maybe I'll look at autos now lol
                            yea i'm hoping it'll go smoothly, the only thing i really have to worry about is getting my gauges working, reverse lights, and do something with the neutral safety switch.
                            anyways, went back to the wreckers today, my dad randomly asked if i wanted to go and grab the rest of the stuff and lend me $100!
                            here's a few pics, then i'll post what we scored.
                              3rd pic was the engine/trans hanging by the p/s line haha.
                              Anyways, I grabbed the transmission, transmission mounts/brackets and all the hardware, flywheel, clutch assembly (not oem, so its been replaced), plus the complete VRIS and vac system from the mx6 intake manifold, maybe they'll work lol.
                              The rear engine mount got a little beat up tho, so i'll need another one, rubber is torn and the housing isn't round anymore lol.
                              Then all I need for parts are a clutch slave cyl, clutch master rebuild kit (might as well), trans axle seals, rear engine mount, polyurethane caulking, shifter bushings, and fluids! well...if the clutch i pulled is any good lol.
