OEM Wheel and Tire Specifications
    Updated September 2013
    Introduction
    This thread is the result of a suggestion made by me109 in which he pointed out that while many of our members use the tire calcs posted in this section to determine appropriate-sized aftermarket wheels and tires to improve handling performance, in many cases the OEM wheel and tire specs are not known with certainty by those attempting this kind of performance upgrade. As me109 stated, without a stable frame of reference for the OEM parameters it's difficult to determine the most appropriate aftermarket wheel/tire combo that will stay within accepted limits of speedo error, and not produce clearance problems, while at the same time improving handling over the stock situation. OEM variables such as wheel diameter, width, and offset are crucial factors in carrying out a successful upgrade here. He recommended that we create a thread listing these variables and I was in full agreement.
    This is a purely collaborative effort between me109 and myself with each of us contributing respectively in the areas we know best. In this post, I will list the parameters for the 3rd Gen Protege and the 1st and 2nd Gen Mazda3.
    In the next post, me109 will provide a listing for the 1st Gen Protege (an area that largely mystifies me). Later, we will also be calling on a fellow collaborator/volunteer to provide the same information for the 2nd Gen cars.
    For references, I've used TheMAN's excellent FAQ in which he has compiled a table of OEM wheel/tire data for the Protege. Access it at:
    I've also used various FSMs, model brochures available from Mazda dealers when that particular car was in production, and material from edmonds.com
    3rd Generation Mazda Protege - BJ (1999 to 2003)
    All 4-lug Protege wheels have a 4 x 100 mm pitch circle diameter and a 54.1 mm centerbore. All 5-lug Protege wheels have a 5 x 114.3 mm (4.5") pitch circle diameter and a 67.1 mm centerbore.
    1999 - 2001 1.6 L
    DX, LX: 14 x 5.5", +45 mm, 4-lug; 185/60-14
    1999 - 2000 1.8 L
    ES: 15 x 6", +45 mm, 4-lug steel (alloy wheels optional); 195/55-15
    2001 - 2003 2.0 L
    DX: 15 x 6", +45 mm, 4-lug steel ('02 and '03); 195/55-15
    LX: 15 x 6", +45 mm, 4-lug steel (standard on '01 and '02); alloy wheels (optional on '02, standard on '03); 195/55-15
    ES: 16 x 6", +50 mm, 5-lug alloy; 195/50-16 ('01 to '03)
    2002 - 2003 Protege 5
    2001 MP3 and 2003 MSP
    17 x 7", +55 mm, 5-lug Racing Hart alloy; 215/45-17
    1st Generation Mazda3 - BK (2004 to 2009)
    All wheels have a 5-lug, 5 x 114.3 (4.5") pitch circle diameter and a 67.1 mm centerbore
    Available Wheels and Tires
    2.0 L 4-Door: 15 x 6", +52.5 mm steel; 195/65-15
    2.0 L 4-Door: 16 x 6.5", +52.5 mm alloy; 205/55-16
    2.3 L 5-Door: 17 x 6.5, +52.5 mm alloy; 205/50-17
    2.3 L Mazdaspeed: 18 x 7", +52.5 mm alloy; 215/45-18
    2nd Generation Mazda3 - BL (2010 - 2013)
    All wheels have a 5-lug, 5 x 114.3 (4.5") pitch circle diameter and a 67.1 mm centerbore.
    2.0 L MZR and SkyActiv, 4-Door: 16 x 6" steel, +52.5 mm; 205/55-16
    2.0 L SkyActiv only, 4-Door & 5-Door: 16 x 6.5" alloy, +52.5 mm; 205/55-16
    2.5 L MZR, 4-Door & 5-Door: 17 x 6.5" alloy, +52.5 mm; 205/50-17
    2.3 L Mazdaspeed: 18 x 7.5", +52.5 mm; 225/40-18
    3rd Generation Mazda2 (2011 - 2013)
    All wheels have a 4-lug, 4 x 100 mm pitch circle diameter and a 54.1 mm centerbore.
    Sport: 15 x 6", +45 mm steel; 185/55-15 V-rated all-season
    Touring: 15 x 6", +45 mm alloy; 185/55 V-rated all-season
    Okay, data for the BG follows.
    1990-1994 323
    Wheel size: 13x5-J
    Offset: 45mm
    Wheel stud spacing: 4x100mm
    Tire size: 155/80/13 79S
    1990-1994 Protege SE/DX
    Wheel size: 13x5-J
    Offset: 45mm
    Tire size: 175/70/13 82S
    1990-1994 Protege LX
    Wheel size: 14x5.5-JJ
    Offset: 45mm
    Tire size: 185/60/14 82H
    1990-1991 Protege 4wd
    Offset: 45mm
    Tire size: 185/65/14 85S
    1990-1994 323 GT-X
    Offset: 45mm
    Tire size: 195/60/14 85H
    1992-1994 323 GT-R
    Wheel size: 15x5.5-JJ
    Offset: 47.5mm
    Wheel stud spacing: 5x114.3mm
    Tire size: 195/50/15 82V
    Temporary spare
    Wheel size: 14x4-T
    Offset: 45mm
    Tire size: T115/70/D14
    Most of the data presented here applies to USDM models and may vary by region. My information is based on the FSM.
    Thanks to goldstar for the awesome implementation of this resource. I hope it's as useful as I think it could be.
    1990 Protege 4WD
    1 3 5
    2 4 R
      excellent write up guys ...
        Thank you.
        If anyone would like to volunteer to post data for the 2nd Gen Proteges we'd be extremely pleased. Also, data for 323 BF and 626 would be very useful.
          I'll post up the 2nd gen info tonight or tomorrow.
          Broke Status FTW!
            Some BF data:
            Wheel size: 13x4.5-J
            Offset: 45mm
            Wheel stud spacing: 4x114.3mm
            Wheel size: 13x5-J
            Offset: 45mm
            Offset: 45mm
            Temporary spare
            Wheel size: 14x4-T
            Offset: 50mm
            Tire size: T105/70/D14
            1990 Protege 4WD
            1 3 5
            2 4 R
              Thanks for further expanding our database, me109.
