FE3-323 goes international!
    YES! when you called me and were like im under a phone booth HAHAHHA
    My baby 93' Protege Lx--R.I.P
    New Baby 94' Protege Lx Black
    91' Miata - SOLD
    93' Protege LX new Project (no rust)!
    Mods: Protege:
    Engine: Fully built with wiseco 9:1 +1mm ceramic coated tops and molly skirts, M-tuned H beams, ACL Race rod and thrust bearings with King Mains, Arp Mains ,rod and head studs,3 lbs lightend crank, Everything is ballanced, spec stage 3 clutch,lightend flywheel, RX7 Afm, Fidanza Adj. cam gears, timing,Cut intake manifold from BPT323, exintake cam swap,full port and polished head 1mm stainless oversize valves, vf12/vj20Turbo, 3" custom full exhaust w/external wastegate,3" E-Cut, Eclipse crushed BOV , Fmic, Aem Urgo wideband, Autometer boost gauge, Magnaflo Muffler,batt relocated to trunk, slight wire tuck with engine bay fuse box under dash Bp26 ecu
    Suspension: Energy Suspension rear trailing arms,Es Front Sway bar endlinks,Zx2 Front Sway Bar,El Sport w/bilstein mono tube struts and don't know what springs, Suspension Tequniques Rear Sway bar with Es endlinks,mx3 rear lower tie bar. corksport SS brakelines and clutch line.
    Exterior: Adler Racing 16"s ,Mx6 Front lip,EGT Glass Sunroof,Edm Headlight & corners EGT side skirts,Gt Led wing, Led interior 3rd brake light
    Audio: few things polk momo 6.5 components, VW Monsoon Front Componants with monsoon amp,alpine head unit
      awesome pictures man!!
        tell me you brought some back!
