So my friend changed my brakes for me and we had left the keys in the ing. for awhile... The car was off but the little lights were on. After we changed them the car wouldn't start because the battery was dead. We tried starting it up with a starter didn't work got a new battery and work but the idle is now extremely low when I stop the car.. I heard this is somewhat normal but my has not stopped. Is there anything I can do to fix it?
Low Idle!!!
Normal idle speed for your car is 650 to 750 rpm. Are you getting a malfunction indicator light (MIL)?
Happy Motoring!02 DX Millenium Red - The Penultimate Driving Machine
