AL4SPN - Evo Drivelined Gtae
    Heres my car is a '88 Mazda 323 Gtae
    Specs are
    BPT Engine
    Autronic SMC ecu
    AVCR Boost controller
    Autometer Guages
    Aeromotive A1000 Fuel Pump Filters and Reg
    JE Forged Pistons
    Forged Rods
    Billet Oil Pump
    Ported and Polished Head
    GTR Valves
    Double Valve Springs
    Toyota 20v Quad Throttle Bodys
    2x Tial 38mm V Band Wastegates, and Tial Bov
    custom twin scroll SS steam tube manifold
    Custom Radaitor and intercooler
    3in Stainless steel exhuast with wastegates plumbed back
    Quater Master Twin Plate Clutch
    Evo 5 Gearbox with custom adaptor plate
    Modifed Evo 3 RS Mech LSD Rear Diff
    Toyota Levin CV's all round
    Custom Axles all round
    Wilwood 4 Pot calipers on front with 300x30mm disc
    Front bfmr discs on the rear with sw20 mr2 calipers
    All custom engine, gearbox and diff mounts
    Racing Logic Coil Over Suspension
    Whiteline rear sway bar
    Whiteline front Strut Tower Brace
    Theres probably heaps more too that i cant remember
    Heres a few pics of my new GTae which AL4SPN and I have been slowly building,
    Good Lord almighty. I done died n' gone ta heaven. Alrighty, now this is my favorite BFMR on CP (as well as Amazd.co.nz). The fabrication (not to mention the science behind it) speaks for itself. Trailrider, your in a very respectable second place.
    So concludes today's awards ceremony.
    Scott F. Williams
    Team Director
    Usually Sideways Rally Team
    www.usrallyteam.com
    856.456.3335
      Holy crap. I'd heard that the evo5 box could be made to fit but no evidence. Here it is though. I'm doing a GT4 swap to my rally Protege, and having one HELL of a time making everything fit, your swap at least looks much easier. Sheeeit you 've got at least 40mm more space between the block and the radiatormount than I do..
      Your rear propshaft isn't in a straight line. The one in my car is much more straight but not perfect. I assume you aren't getting any driveline vibe I hope? This is just one of many concerns I have about my build that I won't know the answer to till it actually hits the road. I won't do a GT4 swap in my street car, but would consider an evo swap. I don't suppose you can source another adapter plate?!
        Believe me its not easy at all lol,Propshaft follows the same path as standard, tho i have made the Diff and gearbox a bit higher in the car so that the axles remain flat when the car is lower instead of point up in to the hubs, driveline vibe i am not sure on as the car doesnt go yet :D but its getting there, as for the plate it was made to suit my car so unless you change the engine angle and that to the same as mine it would be no help, the adaptor plate is actually one of the cheaper parts of the conversion
          Cheers
            The primary reason I went with the GT4 besides more documentation on the intarwebz was parts availability. Evo5 gearbox in the US? Not so much..
              Jay, just change your last name to "McWoodward" and move to the NYC area. You'll have more EVO parts available than you know what to do with. The Irish Rally Mafia reigns supreme over here.
              Now... how about a 4G63 to go with the trans? Mmmmmm.... yum!
              Scott F. Williams
              Team Director
              www.usrallyteam.com
              856.456.3335
                  holy wow haha, that is quite the piece of work! still not sure what to say lol, still soaking it in
                    Finished my cluster completelyand 90% of the other wiring, and mounted my oil filter mount
                      o wow thats really sick. i think i saw this before ova at fordlaser.com
                        Fantastic job.
                          subbed, this looks great, what flywheel you using, im assuming its custom?
                            Yep custom flywheel to mate to the quater master twin plate clutch, and align it where it needs to be for the evo box
                              that is exactly what i thought. very nice work man and i wish you luck with the rest of it going smoothly
