AL4SPN - Evo Drivelined Gtae
    nice time!
    2011 BMW 128i 6 Speed Manual -- dd
    1990 Protege 4WD 5 Speed
      Incredible build. Maybe I missed it but what turbo are you running? Love the mani any chance of having another built? I would love to get my hands on a nice twinscroll, twingated manifold.
      Ian Boyd- Bellingham, WA (click vehicle to view)
      1988 BF GTX
      1990 x2 BG AWD Protege
      1991 Escort GT- SOLD
      1975 911 S Widebody 3.6 conversion
      2005 Corolla
        Awesome build.
        My Hiroshima Screamer
          I am running a turbonetics GTK 450 at the moment, manifold is easy, sadly i am living in the uk at the moment and car is in storage so i cant really help any good performance shop should be able to make you one
            Any way you could post some detailed pics of how you mounted the trans? I've been stuck on the cross member part of doing an entire evo swap
            Also did you use custom axles and drive shaft or did you find some that would work
              There a photos on the first page, mounting is very simple, i have a custom chromoly crossmember and custom top engine and gearbox mounts, axles are custom drag spec as well using evo inner cvs and toyota outers to make sure it stays reliable, driveshaft is custom as well using evo ends and mazda hanger bearing in the center :D
                Not sure how I misse that one, thanks itl help me out an save me a lot of time
                  I read the whole threa this time to make sure it wasn't covered but what did you do for the shifter linkage?
                    ^^ my guess is EVO shifter and cables.
                      Yep Evo shifter and ables mounted in the standard place
                        Wow, havent updated this in a while!
                        Cars now running full gtr hubs, with gtr rear brakes and my wilwood setup up front, have BBS LM's for street driving and Evo 4 wheels for drag racing at the moment,
                        Still havent gone faster than 11.3 but have some intake temp issues that i am trying to sort then I might finally get that 10sec pass.
                        Also had a the gtae graphics reproduced down the side not 100% but pretty good
                          Where was I for this????? Sadly all the photos don't work.
                          Looks impressive though!
                          Mazda
                          1988 Black 323 GT
                          DOHC 16 VALVE TURBO
                          2013 Velocity Red Mica Mazdaspeed3
                            Did a few little things on the mazda over the weekend, on the quest for a bonnet I found this at zebra
                            Finally have white heater controls
                            From this
                            To this
                            Also wrapped my down pipe in titanium lava wrap, seems to have brought the under bonnet temps down a bit, also swapped my cam cover out for another one as mine had cracked around my intake stays.
                              This is one the best BF323s out there. Great to see its still going and receiving attention.
                              mazda stands by you
                                Cheers :D
                                Have been doing some more work on her
                                Upgraded the intercooler to a HDi GT2 600x300x80mm one as the old one just wasnt big enough for the power level,
Name:	2015-07-27 00.27.33-2.jpeg
Name:	2015-07-27 00.27.33.jpeg
Name:	2015-07-27 00.27.33-1.jpeg
