AL4SPN - Evo Drivelined Gtae
    ATI Damper and Arp flywheel bolts arrived, ran my battery cable and mounted the main fuse holder.
    Also Picked up a Gate Racing Cam Belt, Acl Race Series Main and Big end Bearings, Idler, Tensioner, Thrust Washers, Water Pump, and high flow thomostate today think i have everything to build the motor now :D
    Gizzmo Shift light in, and wiring is finished :D (have a gizzmo launch contral interface to wire in but ill will get the car running before cutting into the engine loom), also mounted a rear water sprayer bottle in the front so engine bay is now finished, just my vaccum block to do and the tear down for paint can start
      Off to panel and paint
        That is a bad mamma jamma!
        "Who Dey"
          That is all
            Can't wait to see this finished!
              this car looks pretty damn sexy as is on the trailer. cant wait to see what she looks like all painted up
                Sun came out today so took a few pics, still waiting on clips for the rear window moldings, then the bottom spoiler will go on,
                  wow looks mint man
                    The car looks cherry! Nicely done!
                      car look awesome man. time for assembly
                        Car is mostly back together now, change a bit of the wiring to make it tidyer, but all tirm windows etc are now on just waiting on bottom spoiler, dash is back in, polishing is all back, just need the engine back to start on the engine bay
                          It reminds me of Quicksilver's car
                          "Who Dey"
                            That is a beautiful color! I like it
                            FS Forged H beam rods
                            awaiting test fit
                            Aluminum CAS/Distributor caps
                            BP oil jet eliminators
                            EV14 fuel rail spacers
                            More stuff coming soon.......
                              car looks good, you are going to dislike that ATI damper when it comes time to rebuild it... or do a timing belt, I hear they are a pain to press on and off and are tricky to rebuild.
                              1990 Protege 4WD 5 Speed
                                They arent too bad to get on, getting them off you use the proper tool and they should come off fine, however i dont entend to be pulling the motor down :D
                                Quicksilvers old laser is awesome always liked it, my colour is a fair bit darker tho
