Pics of under the back of car
    I'm going to be doing some work back here so wanted some pics to reference.
    I'll probably be post more later as needed.
    1991 Protege LX with GTX swap, DD
    1990 4WD Protege with GTX swap, Project/garage decoration
    2006 Mazda 3 with 2.3, Her car
    1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
    honestly it looks like its in fairly great shape for its age & all
      Perhaps some new bushings are in order ... are you going to coat it in something like Por15?
        look at that, all shiney and clean!!
          Ha! No leaky rear diff seals for you. Looks good.
          1990 Protege 4WD
            wow doesn't look bad under there at all! just some bushing rot from what i can see, glad to see its pretty solid underneath!
              Hope this helps
                stuck,
                lots of good AWD pics for people like me who have never actually seen one
                  better than my 4wd rear end... hopefully going to tackle that over the summer
                  2011 BMW 128i 6 Speed Manual -- dd
                  1990 Protege 4WD 5 Speed
