Hi I've broke my transfer box in my bg gtx and can't find a crown wheel and pinion anywhere or a gearbox but I have found a bf 4wd box will the box fit? Or if not is the transfer box interchangeable? Thanks
Will a B6t 4wd gearbox fit my 1991 4wd gtx?
if your changing just the transmission, it should work just fine, people use the BG AWD transmission in BF's as an upgrade, so why would it not work the other way around
1988 323 GT - B6T Powered
Yah but we usually swap engines while we're at it. I know a guy with a gtx who kep the b6t and used the bpt box, 2 boltholes don't line up, and there may be some grinding involved but I don't know about that for sure, going the other way.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
bg chassis Protege 4WD's have the same internals as a BF GTX just in a bg case. a bg GTX/GTR get the "better" parts like gears, center lsd"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by neuspeedescortthe proper spelling would be "Launchabilitiness" i do believe.
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
