Not the greatest pic but i just got my D2 coilovers installed, still kinda adjusting everything since teh rears seem to have settled lower then the fronts. Also i got some pretty good rear camber and toe that i have to address but this is how shes sitting now!! I will be putting my new clutch and flywheel in soon!! WHOOT also ill be fixing the horrible rim condition. More pics to come.
Slammed PGT
Slammed PGT
Not the greatest pic but i just got my D2 coilovers installed, still kinda adjusting everything since teh rears seem to have settled lower then the fronts. Also i got some pretty good rear camber and toe that i have to address but this is how shes sitting now!! I will be putting my new clutch and flywheel in soon!! WHOOT also ill be fixing the horrible rim condition. More pics to come.1996 PGT<CAI, muffler delete, D2 coilovers, Fidanza, Southbend Stage 1, G4 IM
1997 Integra RS<CAI, header, exhaust, lowered on BS with Piles old 17" rims
2001 Maxima<wifes dailyTags: None
yep that's pretty low lol, good job man. I'd definitely recommend an alignment asap though, could cause premature wear of your tires and suspension components.-Jack
Originally posted by monoxidechild View Postyou dont even want to get him started on the alignment issues. lol1996 PGT<CAI, muffler delete, D2 coilovers, Fidanza, Southbend Stage 1, G4 IM
wow that's some crazy camber and toe lol.
are the fronts/rears even interchangeable? wasn't aware they'd even bolt in-Jack
Originally posted by Mazda_Powered View Postwow that's some crazy camber and toe lol.
are the fronts/rears even interchangeable? wasn't aware they'd even bolt in1996 PGT<CAI, muffler delete, D2 coilovers, Fidanza, Southbend Stage 1, G4 IM
ahhh, gotcha. Ya they would be able to change left to right, I BELIEVE the only different should be the flex line tab, but I could be mistaken!
You should be able to adjust your toe tho on a rack, the back has a few ways to adjust all that crap out, OEM cam bolts, ect.-Jack
Yea they're seized tho....but i do believe your right, i think the only diffterence is the tab. But its worth a try! But like i said if this doesnt work im gettin the Protege adjustable lateral bars. But im thinkin with those if i fix the toe and the camber that its goign to suck in my wheel...1996 PGT<CAI, muffler delete, D2 coilovers, Fidanza, Southbend Stage 1, G4 IM
Well you can fix the camber with some crash bolts if it really bothers you that much...bring it to around -1.5 degrees or so, it seems tolerable on the streets. It'll only bring the top of your wheel a wee bit closer to the fender lip lol.
Never knew about the Protege rear adjustable arm swap, pretty neat!-Jack
Originally posted by Mazda_Powered View PostWell you can fix the camber with some crash bolts if it really bothers you that much...bring it to around -1.5 degrees or so, it seems tolerable on the streets. It'll only bring the top of your wheel a wee bit closer to the fender lip lol.
it's easy for a bit, then you eventually crawl back haha.-Jack
Originally posted by Mazda_Powered View Postit's easy for a bit, then you eventually crawl back haha.1996 Escort LX SOLD!
1993 Escort GT Motor Pulled then Shell Scrapped
1995 Escort LX BP Swap, atx=mtx swap, boosttt! Shell scrapped
1994 Mercury Tracer BP-T Daily Driven
1993 Mazda Protege LX Parts Car
Originally posted by kylespatula View Posti think its the whole fact that KLs are POS... or atleast from what i hear.1996 PGT<CAI, muffler delete, D2 coilovers, Fidanza, Southbend Stage 1, G4 IM
