It's had this problem since I got it, and I figured it would be an easy fix, but not so far.
Symptoms:
- Erratic idle, appears when warm, worst after a hot/warm start
- Severe hesitation and missing, appears when warm, worst after a hot/warm start
- Occasional stalling after warm/hot start.
MIL is constantly on, sometimes flashes. Codes are for random misfire, cyl 3 misfire and "fuel trim" (research showed this is really a "boost sensor" code). All codes eventually return if reset.
I have read up on the usual suspect - the EGR valve. I cleaned it and noticed no difference. Unplugged it and noticed no difference. Blocked it off and noticed no difference.
I have also tried removing the vac lines to and unplugging the boost sensor, no difference there either. (Aside: "Boost sensor?" on an NA car? Silly name for it). I've cleaned the MAF and checked for vacuum/intake leaks.
The car has new plugs, wires, cap, rotor, air filter, and I've replaced the fuel injectors (had a spare set). The plugs themselves look fine - though they read a bit rich (fuel economy around 27mpg so it's not running too rich).
So what's up here? I don't want to throw money at this car because I don't have money to throw at it. What's the next suspect now that I've eliminated the usuals?
Thanks.
Symptoms:
Thanks.
