Clunking Noise - Rear Passenger Shock
    Look at the pic - the silver washer/nut combo is moving up from the black cap when the car is in motion and when it comes back down, I get the clunking sound. I removed the shock/spring assembly but everything "seems" fine. Is there supposed to be a rubber silencer in there or is the shock bad?
    Is that nut tight?
      Yes, as much as I could with the car on the pavement...
        I think it'd be preferable to take it out of the car and tightening it!
          I just did a side on my bg hatch a couple of weeks ago,replaced it with a generic crap type,stock one rotted right to hell.Mine makes a clunking sound as well,just did'nt look where it was coming from, could'nt be bothered.Bet its the same problem.
            I did take it out and it wouldn't tighten any more...
              ya you can tighten them in the car, there's access holes in the back to even get an impact gun in there lol...
              If it's clunking it can be either a bad strut or possibly swaybar link bushings (end or frame mount)
                make sure the washer isnt stuck on the slot and moves up and down so the nut can tighten all the way down, i had one of mine do this one day when i did mine in the driveway.... it basically held the nut from going any farther, i pulled it off grabbed the strut with vise grips lightly and tried again....
                92 protege lx-
                94 protege lx-
                  make sure the spring is straight and perched properly
                    The nut looks loose, try tightening it first. if that doesn't work. your strut mount is bad.
                      Ok, I'll check if the washer is stuck too high which makes sense and get back to the forum. Thanks!
