I am putting my 323 gtx up forsale.
It has 142,000 miles I bought it not running turned out to be bad ecu. so i converted the car to an mx-3 wireing harness distributer and coil, has a lex built pnp megasquirt and bpt 330cc injectors. Car is tuned on 12psi and pump gas. the stock turbo went out on the car so i built a vj-14/vj-20 hybrid turbo for it. Then built a custom front mount for the car useing 2.25 pipeing and a revhard intercooler. the car has a turbo back 2.25 echaust open dumped before the rear axle. The car has some rust all fixable the cars chassis is sound. The interior is in great shape but could use a good cleaning havent ever got around to it should clean up really well. the paint is in pretty good shape. tires have good tread but are old. the brakes are good all the way around front are slightly warped not real bad. The car will need a head gasket put in it will drive just fine but the headgasket leaks oil externaly no coolant or oil mix. it either needs an igniton swith or a starter will inclde a known good starter. Needs 4x4 lock motor reinstalld have a good one. has new water pump, t-stat, timeing belt, and radiator. need a fan installed i have ot installed one because i havent been city driveing it wont get hot unless stop and go traffic. needs a heater core leaks into the car. all in all its in really good conditon for its age and due to the rarity of the car i want to sell it driveing. it will drive fine to where ever. Thanks for looking pirce is $1500 obo.
