So the summer is here and it looks like the ac compressor on my 91 lx is not helping out much with my cooling needs! I am new to this forum and after much researching around I have decided to post up my issue on here. My compressor clutch will not activate when I press the ac button and turn the knob all the way to cold. I thought that maybe the compressor will not work if the ac system didn't have any freon installed so I went ahead and installed the 134 plugs on my r12 inlets and filled my ac system. I have to point out that the only way I can get my ac clutch to activate is by wiring a cable to the battery straight to the compressor cable. I have tried replacing the the ac relays and nothing! So to sum things up, I can not activate my ac compressor clutch without wiring it straight to the battery. The ac compressor clutch will not cycle, it will just keep spinning and to top things of there is a loud scratching noise coming from the compressor when I activate the ac clutch.
somebody please help????
