Wiring in gtx ecu
    Wiring in gtx ecu
    Trying to repin the harness so I can run the gtx ecu in my escort. I have the pinout tables but I'm mentally deficient it appears. It shows what pins are different, but what do I actually cut and then wire into a different position? I can wire, soder(sp), etc but understanding what I need to do to make things work in this case is confusing me.
    Have 3 wire tps FYI
    plug it in and go stop getting soo cornfused...lol.... the only thing your would change is if you added a 4wire tps..lol... why dont you just ask sometimes...lol...
    92 protege lx-
    94 protege lx-
      you shouldn't cut and splice anything. you can remove the pin from the plug(s) lol
      -Steve
      94' Protege < Worklog<SOLD!
      VF10 powered!
      262 Whp & 257 Wtq
      13.1@107
      '02 Suzuki Bandit 600s
        one day hell learn, one day....lol....
        92 protege lx-
        94 protege lx-
          As you can tell, one day I will not l
            Lol. I thought there was definately something to move? Have to look at pin layout again though
              here's the pin out link
              and here's the link I used to wire in my 4 wire tps for the GTX ECU
              the main part you need to know from the feoa link is this tho
              "All you really need to do is put the throttlebody on, cut the 3 wire plug off and connect color to color, run an extra wire to the ecu and connect it inline with pin 6 the wire is LG/R and move the LG/W wire from pin 19 to pin 7 on the ecu plug, pin 7 is between a red wire and LG/R wire. "
                So truly if not running 4 wire then no wiring needed as Josh said?
                  i ran my stock bp before i went turbo on the gtr ecu just to make sure it ran, its deffinatly pnp. you only need to splice into the 5v off the afm if you go to a 4 wire tps so it gets signal.
                  92 protege lx-
                  94 protege lx-
                    Good thing I asked, I would have screwed with things... Lol
                      i want to punch you in your d!ck
