Just as the title states, I'm having a "rattling"(for lack of better words) noise from my head once the engine is around 1800rpm and above, but ONLY when it is part , or light application of the throttle.
Its a brand new (reman'd) head and a new short block. However, when I out the head on, I did (newb mistake) put the HG on backwards and it blocked the oil supply to the head (Chevy HG's only go on ONE way). I drove it like that, not knowing what the issue was, for approx. 250 miles. But fresh oil was getting to the head.
The car runs perfect, but that sound gets to me, as I know its not suppose to make that sound (or is it?). It kinda sounds like the lifters need to be tightened on a sb chevy, but these are adjusting, if I read correctly.
Any ideas? It'll be awhile before I can do anything, but it'll be good to start planning now on what I need to fix, since I need to replace the oil pan gasket, fix the ac, do the rear power windows, paint the tan plastics black, fix the gap from the manual seatblets, etc and I should be able to knock all this out in one day.
So what are your thoughts? I can get a soundclip is yall would like.
