300zx's ELX work log
    could be the IAT as well, they will act a bit funny til they get to a certain temp.
      Nice thread!
      91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
      95 Probe SE- Sold!
      95 Escort Pony- N-1 coilovers, Weapon R CAI, clear corners, and Corksport tower strut bar, Lowtek struts, Moog swaybar endlinks, custom cat-back exhaust, tinted taillights, EGT side skirts, EGT front and rear bumpers, custom short shifter, clear side markers,
      custom painted and dyed interior, MX-3 seats F&B, MX-3 center armrest. some day BP swap.
      91 EGT- Eibach springs, Pacesetter header, custom 2.5 " catback to a Megan Racing muffler, 17" Motegi wheels and K&N cone filter.
      The rest is bone stock.
        Thanks
        Well I think i figured out the bogging problem after reading a few other threads on the subject, and the hidden idle A/F ratio screw adjustment did the trick it seems. Screwed it all the way in and backed it out a 1/4 turn at a time. At 3/4 of a turn right now and all seems well.
        FS Forged H beam rods
        awaiting test fit
        Aluminum CAS/Distributor caps
        BP oil jet eliminators
        EV14 fuel rail spacers
        More stuff coming soon.......
          could be o2 sensor takin a dump.. pull any codes?
          1992 MX-3 GS - KLZE
          1997 Probe GT
          Its not a BP05.... Its a BPOS... BIG PIECE OF ****
            I do have a MIL popping up while cruising when it bogs down still, so it looks like that adjustment really didnt help much. I plan on pulling codes, and getting a universal 4 wire O2 sensor wired up since there is no telling how old that single wire one is.
            awaiting test fit
              LOVE that gauge placement. Good work there man.
              '88 323 sedan, K-swapped..
                Thanks, I cant wait to get the rest of them. I was almost thinking of getting a tach mounted on the other side in place of the stock one.
                Well today I pulled the codes and discovered that I had 2 codes for the O2 sensor. I bought a Universal 4 wire Bosch sensor today and decided to wire it in.
                Since this car was previously an LX(1.9) it already has a separate circuit and fuse for a heated O2 sensor. Since the wiring harness I am using is from a 91, it only had provision for a single wire sensor.
                This wiring how-to really only pertains to a car with my unique combination.
                There is already a wire in the LX harness (C202) to provide power to a heated O2 sensor. I removed the wire from the 1.9 harness I still had lying around, added it to the engine harness side of the (C202) connector and ran it to my bulkhead connector I added when I swapped the engine to make running wires like this easy.
                I ran the power wire to the sensor, cut the connector off the signal wire and spliced it to the sensor. The remaining 2 wires from the sensor get grounded and your finished. Easy.
                I would have snapped a few pics, but I couldn't find my camera at the time.
                The good news is there is no more bogging but the power felt low, so I decided to try and tune the U/K VAF. I tried to use the multimeter but was not having much luck, and the VAF did not seem to respond well at 5/6 clicks. So I resorted to the adjust and drive method, and it now feels good and pulls hard at 4K and up, but the VAF is now 10-12 clicks which seems way further off from everyone else, but it seems to run best there.
                awaiting test fit
                  Well yesterday I finally installed Jim Pierces tubular front control arms, installed new tie rod ends, lowered the car a little more in front, and aligned it all. Was outside in the dark setting my alignment. Still have to get the hardware to install the swaybar drop links as well
                  1.5 degrees neg camber and 1/32nd toe in in front.
                  Got my Jim Pierce tubular rear crossmember back from Jrally with the ES bushings he machined to fit MX3 TTL's. That will be installed along with the EGT rear disc conversion and miata brake upgrade
                  awaiting test fit
                    Today I finally going to try and install the BMW variable TPS I got from Jinx.
                    Problem is that since I am still on the stock ECU and not running megasquirt, I cant just follow the Miata how-to I found online.
                    Here are the wires and there functions for each type of sensor:
                    MTX 3 wire:
                    R/W--IDLE
                    LG/W--WOT
                    BK/W--Ground
                    ATX 4 wire:
                    R/W--IDLE
                    LG/W--Potentiometer signal
                    BK/W--Ground
                    LG/R--VREF from VAF
                    BMW Variable TPS:
                    1--Potentiometer, VREF
                    2--Potentiometer, Ground
                    3--Potentiometer, Signal
                    4--Switch, IDLE
                    5--Switch, WOT
                    6--Switch, Common
                    Now the schematics for visual reference:
                    So basically my wiring plan from looking at both schematics is this:
                    BMW Variable TPS------------------------Mazda/Ford TPS wiring:
                    1--Potentiometer, VREF----------LG/R, VREF from VAF
                    2--Potentiometer, Ground--------BK/W, Ground
                    3--Potentiometer, Signal---------LG/W, Potentiometer Signal
                    4--Switch, IDLE-------------------R/W, IDLE
                    5--Switch, WOT---N/A
                    6--Switch, Common---------------BK/W, Ground
                    Let me know if you think I am off track on this
                    awaiting test fit
                      is 6 common ground? or common power?
                        I have no idea exactly, but I have a feeling after checking this thing with the meter that its a common ground. So to make it work like a 4 wire TPS, I cant just hook up #4 on BMW sensor to the IDLE wire on the harness for it to work. I will have to actually hook up #6 to ground and #4 to the IDLE wire to complete the circuit.
                        I have adjusted my wiring in my last post to reflect this.
                        awaiting test fit
                          Well this sensor will not work with the OE ECU at all. Period.
                          Got it all together and tried it out, wont rev past 2K unless your over 1/2 throttle. Found out the IDLE circuit stays on too long and at part throttle the ECU still thinks its on idle and does a fuel cut or something. Disconnected the IDLE wire and it works great but will sometimes stall after revving it and starts to idle rough. Decided to test the signal part of the TPS just to make sure it was ok, but its backwards. The BMW sensor is 4.5V at idle and 1.2-1V at WOT. The OE ECU is looking for about .5V at idle and 4.5-5V at WOT.
                          So I now have a hillbilly setup rigged up for the idle switch to make it drivable and will go hunting tomorrow morning at the junkyard for a 4 wire TPS. Cant reinstall the 3 wire since I took it apart and used the connector and pins to adapt the BMW sensor wires to the factory stuff.
                          awaiting test fit
                            Hey I just read up on your update and sounds like the BMW was a waste for you but maybe a plus for me! Ill tell you wat I have a 4wire that im not using but if we can get that BMW one to work on my car then you can have the 4 wire tps lol. LMK man
                            Anyone knows what 9K rpm feels like? I do
                            93 Mercury Tracer SW
                            01 Honda S2000 Future Boost
                              damn that's rough man, sorry to hear it didn't work out!
                                Sorry I am still keeping the sensor as I will be going with MS in the future.
                                Its all fixed now, found a 4 wire at the first JY I went to and a couple other things I needed.
                                Also I took a real close look at the Kia Sephia BP upper intake mani, and it appears that its designed in a similar way to a GTR mani on the inside the way the furthest cylinder is shrouded compared to the closest one. Also looks like because of it, that all 4 runners are actually 4 different lengths, with number 1 being the longest and 4 being the shortest. The Kia BP has 5 less HP and 3 more lb ft then a EGT engine and the power peaks about 500RPM sooner, so that manifold may have some part to play in this I think.
                                I would have snagged it to try but the TB setup is completely different and so are the TPS and Idle air control, so I would need the whole setup with pigtails and someone already robbed the sensors off it.
                                awaiting test fit
