Results 1 to 6 of 6
Thread: my way of fixing broken brake lines
  1. #1
    Registered User tym2pla7's Avatar
    Join Date
    Feb 2011
    Location
    Whitby, Ontario
    Posts
    483
    Feedback Score
    1 (100%)
    how to do a double flare so to start off you will need these tools to do your broken brake lines
    once you have cut your line in a place where it is not rusted place you male fitting on the line if you do not you will have to cut off you flare you just did and redo it , and that is a pain in the ass did it twice today
    so once your fitting is on the line place the flare bars on the line make sure there is enough line sticking past the tool, you do this by using the shoulder of the adapter disc for the appropriate size of brake line that you have so in my case 3/16 once you have enough sticking out tighten the wing nuts done once you think there tight do it some more because it will move and you flare will **** up
    now get the clamp and start to screw it in till the adapter disc sits flat on the flare bars that gives you your basic single flare not as good as double
Size:  124.4 KBName:  4.JPG
    now screw the clamp in to the single flare till it gets tight and that should give you your double flare
    if it doesnt look like this it means you forgot your fitting so start over as i said i forgot it twice
Size:  113.8 KBps.. i know the pics are **** yell at apple for there camera in there phone
    handed down to my old man : 1994 Escort gt
    Race car: 1991 EGT BP/bpt
    http://www.clubprotege.com/forum/sho...racecar-s-life
    daily: 2004 mazda 6
    http://www.clubprotege.com/forum/sho...678-TheSexySix
    Welcome to Canada
    ''It's a shame that today's car forums have "fashionistas" instead of gear heads''
  2. #2
    Senior Member Georonimo's Avatar
    Join Date
    Sep 2006
    Location
    Hudson Valley, NY
    Posts
    1,230
    Feedback Score
    9 (100%)
    Quote Originally Posted by tym2pla7 View Post
    Fun times! I just had to make about 9 or ten of those damn flares when I redid my rear brake line from the master back. I ran it through the passenger compartment so I could tie in my bias valve and hydraulic hand brake. I forgot to put the fitting on one of the flares in the worst possible place. Ran the line through one of the bolt holes for the rear seat belts and it just poked out of the floor pan above the gas tank about 5 inches... Talk about fun on a cold garage floor at 2am the morning of an autocross
  3. #3
    I smoke more then a Speed6 monoxidechild's Avatar
    Join Date
    Aug 2007
    Location
    ROCKFORD,ILL
    Posts
    1,921
    Feedback Score
    1 (100%)
    they sell the lines in foot different length's. i always just buy the longest one they have. which is usually 6 foot. run that one. then measure from where that one ends, to where it needs to go. then go back to the store, and buy a 2nd line the length i need. that way i dont need to cut, or flare a single line.
    after doing my own lines and flaring them when i worked at the shop. this is just way easier. no specialty tools. and no leaks ever. WIN!
    ~PaTricK~
    -Current car's-
    What are you driving?
  4. #4
    Registered User
    Join Date
    Feb 2007
    Location
    Norfolk VA
    Posts
    324
    Feedback Score
    0
    Nice work. I would have never been able to come up with such a method.
    Its I good thing that there a salvage yards in the south were it never snows.
  5. #5
    Registered User
    Join Date
    Oct 2006
    Location
    Glendale hts, IL
    Posts
    825
    Feedback Score
    3 (100%)
    Quote Originally Posted by monoxidechild View Post
    +1
    the only time you should bother cutting and flaring is when you need two different style fittings on the same line.. this typically happens with GMs and some Ford trucks..
    plus you should never flare an old line as your risking stress cracks at the flare point which leads to more leaks later on..
  6. #6
    Wake and Baked The Pile's Avatar
    Join Date
    Aug 2009
    Location
    Rockford, Illinois
    Posts
    858
    Feedback Score
    5 (100%)
    ^^^^ Yea we did my entire protege in like an hour, both rear brake lines from the PV to the calipers
    1992 MX-3 GS - KLZE
    1997 Probe GT
    Its not a BP05.... Its a BPOS... BIG PIECE OF ****
Thread Information
Users Browsing this Thread
Similar Threads
  1. Brake Lines
    By Brandon6103 in forum Suspension/Brakes - BHA Chassis
    Last Post: 09-15-2008, 07:42 PM
  2. Brake Lines
    By protege94 P.R in forum Suspension/Brakes - BG Chassis
    Last Post: 12-21-2006, 07:59 AM
  3. Question about brake lines for a rear brake swap.
    By Mazda_Powered in forum Suspension/Brakes - BG Chassis
    Last Post: 11-07-2006, 10:02 PM
  4. Fixing the Broken swaybar & fitting new endlinks
    By FE3-323 in forum Suspension/Brakes - BG Chassis
    Last Post: 10-19-2006, 07:12 PM
  5. Where can I get SS brake lines?
    By 1967cutlass in forum Suspension/Brakes - BG Chassis
    Last Post: 07-25-2006, 12:09 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
