I searched a lot, I know there aren't interchangeable. Does anyone have install a small nose crank pulley on a big nose crank with modification? I changed the block yesterday and I have to use the small nose pulley as the magnet were bolt behind it to run with the crank sensor of my SDS standalone. Thank you
HELP!!! Put a small nose crank pully on a big nose crank
for the required modding. you might consider remodifying the big nose pulley for the magnet.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
