My Stroker 2.2 in the build(Lots of Pictures)
    It's not at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it.
      lovely cam gears
      I like that you route it through the sheet metal. certainly helps clean up the bay. stoked to see all the progress.
        Sorry for your loss. I hope you are healing ok. Great work on the intake manifold.
        "Who Dey"
          Sorry to hear about your wife.
          Sent from my iPad using Tapatalk
            Thank you, 1 August its 2 years already
              got the brackets for the 4 link suspension
                well got the diff back tonight, it's been made shorter to fit into the Anglia
                  thats one fancy unit. how many mm's did you have taken off each side?
                    About 420mm of each side, want to put at lease a 275/40/17 tyre on[emoji16]
                      hehe, thats some tread!! should stick well
