My Stroker 2.2 in the build(Lots of Pictures)
    Originally posted by Turpro View Post
    Surprised fe3-323 isn't here jerkin it already lol. Nice build. What numbers you looking for?
    Just kidding
      What pistons??????
        Yes they are low Comp, but not stock, Wiseco pistons
            ^ did you mean to post something new??? hows the build coming along?
              Update
              Well assembly has started, here is some pictures
Name:	O-Ring block 2 web.jpg
Name:	ARP Studs block web.jpg
Name:	Mazda Fe diesel gearbox 1 web.jpg
Name:	Oil Pump and Water Pump web.jpg
Name:	O-Ring Block 1 web.jpg
                looks good!!!
                  Thanks.....
                    is that the 6spd mazda 6 diesel trans?
                      Yes it is the Mazda 6 Diesel trans, had the starter relocated to the other side of the gearbox.
                        Looks great! Keep on working!!
                        -1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
                        -2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
                        -2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
                          you should have grabbed a 09+ MZR 2.5 mtx 6 speed. they have the same bell housing bolt pattern as the G series used on the f2/fe3. so you could potentially swap the bellhousing side of your f2/fe3 trans to the 6 speed mtx, and run it.
                          ~PaTricK~
                          -Current car's-
                          What are you driving?
                            My gearbox what i got I imported it from the UK, it is a Mazda 6 diesel 6 speed gearbox, but i also got myself a Mazda 3 MPS 6 speed gearbox, i will be using the Mazda 3 MPS gears.
                            More info on this, is there a thread that explains more on how to adapt to FE/f2 motors? How are you swapping gears exactly?
                            1993 Mercury Tracer, KLDE VItara build swap, Compound turbos, 12 injectors, 2 wastegates, 2 Megasquirts, 2 axles, 2 everything, why not
                            2nd Compounded KL in the world
                              A Bit Of A Update Here
                              Powder Coat yellow and red
Name:	Tapper Cover web.jpg
                              After 26 month the car has got a Motor and Gearbox
Name:	Car and motor web.jpg
                              Front Engine Mounting been ma
Name:	Front Engine Mounting !.jpg
                              Flexi Plate
                              Gearbox mounting been made
Name:	Gearbox Mounting 2 web.jpg
                              Mazda Fe Dohc with the Mazda 6 Diesel Gearbox
Name:	Mazda 6 Diesel 6 Speed Gearbox 1 web.jpg
                                Well some more pictures here, just got the Intake Manifold and Engine Mountings done
                                Intake Manifold Front
                                Intake Manifold Back
                                Cam side Mountings
                                Gearbox Side
                                Rear Gearbox Mounting
                                Tapper Cover
