It's not at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it.
My Stroker 2.2 in the build(Lots of Pictures)
lovely cam gears
I like that you route it through the sheet metal. certainly helps clean up the bay. stoked to see all the progress.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
thats one fancy unit. how many mm's did you have taken off each side?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
hehe, thats some tread!! should stick well---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
