Originally posted by goldstar
View Post
Megan Lateral Links installed
^ Yes, thank you for the correction.
I'll go back and change it.
Happy Motoring!02 DX Millenium Red - The Penultimate Driving Machine
goldstar, thanks very much for adding the tourqe specs.
speed, so far so good. I really like them. They handle much better than the oem's.
the only thing about these vs the aac ones is the megans dont have the adjustments to pull the wheel in. They are the same length as the stockers. They do have the add adjustability of toe which is good.
If you're looking for an upgrade in handling and not too worried about pulling in the wheels, then these will work just fine.
Originally posted by o.g.sk8er View Postgoldstar, thanks very much for adding the tourqe specs.
I'd also like to point out that this thread is also a good tutorial for those replacing their stock rear stabilizer bar with the MSP/MP3 type. Bar replacement requires also replacing the rear subframe with a new one, included as part of the MSP rear stabilizer bar kit. This thread provides a How-To for that proceedure.
The gift that keeps on giving.
im confused.... why would you want to pull the wheels inwards???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
with some of the more aggressive set ups that have low offset wheels, its nessessary to pull the rear wheel inward to avoid any rubbing. the rears of the p5s are quite narrow so an adjustable lateral link kit may be needed for some.
and yes goldstar is correct. this can double for a how to for installing the rear sway as well. indeed the gift that keeps on giving.
None of that is "proper". Changing track width isn't the way to do things.... then again super slammed isn't either lol---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
