Page 294 of 313 FirstFirst ... 194244284292293294295296304 ... LastLast
Results 4,396 to 4,410 of 4681
Thread: What did you do to your BG(part 8)
  1. #4396
    Registered User
    Join Date
    Apr 2009
    Location
    Titusville PA
    Posts
    154
    Feedback Score
    0
    Been off of here for a while, but need help - Mazda disease is eating me!
    Now I have 3x 323, 4x Protege, 2x MPV, 1x Mercury Capri, and a couple of B6 DOHC Miata engines (one is all of a Miata except the body panels)
    Think I will be needing some B6 DOHC head and intake parts to put one of the Miata engines in daughter's 323.
    Went by Greyhound to Tennessee last week and drove the second MPV home, my first one needs more work than I have time for now - so I fell into this NO RUST one to replace it. Drove 600 miles home, didn't realize til the next day the tires are oversized, so my gas mileage was about 20mpg at 90mph!
    FRM
  2. #4397
    I'm on a boat. Kitty's Avatar
    Join Date
    May 2006
    Location
    Oahu, HI/ The ocean
    Posts
    3,153
    Feedback Score
    17 (100%)
    Did the ghetto replace the rod bearings only fix today. Only big issue I had was one of the MBSP bolts heads rounded off and because of how soft and small they are I had to air hammer it's head off. I was impressed I didn't damage anything in the process.
    It was number 4 that bit the dust although the other ones were showing their age. Oddly enough the #4 rod journal was in the best shape out of any of them. I'm guess in self machining it somehow polished itself. Only rod journal one didn't pass the fingernail test, I'd wrap that up to it being first in line for debris. I only bothered checking the oil clearance on 1 and 4 . 1 was ~.035mm and 4 was .050mm. I mineral spirited the oil passages the best I could to loosen any bearing flakes but most of them were at the bottom of the oil pan to start and I trust most of the remainder now live in my old oil filter. Crank play was nonexistent and if the engine didn't burn oil I'd trust the damn thing for another 50k if it doesn't **** the bed on cranking tomorrow.
    Also I snapped an oil pan bolt at 50 in/lbs. **** those bolts.
    Beater=/= Sleeper
    Quote Originally Posted by kozzman555 View Post
    Quote Originally Posted by HopelessCow View Post
  3. #4398
    ダンスは犯罪じゃない。 atomicEGT's Avatar
    Join Date
    Mar 2005
    Location
    305
    Posts
    7,998
    Feedback Score
    27 (100%)
    I wonder which is the sketchier method of removing that bolt, air hammering the head off or using a size smaller socket and hammering it on so you can remove it normally
    I managed to snag the street parking spot directly in front of my apartment over a week ago and haven't touched the car since, because a) I don't want to lose that spot and b) I can walk to the majority of the places I need to go. living in a real city is weird.
  4. #4399
    azgtx
    Join Date
    Nov 2006
    Location
    Mesa AZ
    Posts
    1,452
    Feedback Score
    30 (100%)
    Quote Originally Posted by atomicEGT View Post
    Does the hose reach to the street so you can wash it now and then? Don't want it to look abandoned you know.
  5. #4400
    Join Date
    Mar 2005
    Location
    305
    Posts
    7,998
    Feedback Score
    27 (100%)
    I've been waiting to get a ticket or something, it's covered with leaves from being parked under the tree and it has CT plates on it... nothing yet, but I'll be driving it in a few days anyway so I'm not worried about it.
  6. #4401
    Join Date
    May 2006
    Location
    Oahu, HI/ The ocean
    Posts
    3,153
    Feedback Score
    17 (100%)
    I tried the smaller socket method first, it just took some metal off on first turn. Air hammering is probably the best option for the scenario as cutting will just get metal shards everywhere.
    BG is on the road again and purring, it got a fancy cast aluminum HKS VAF filter adapter for being such a good sport.
    My spare block also fell on the ground while on the engine stand and broke the crank boss. Fun day overall.
    Beater=/= Sleeper
  7. #4402
    TOKEN KOREAN leica's Avatar
    Join Date
    Dec 2009
    Location
    Florida
    Posts
    205
    Feedback Score
    0
    Back in the BG game again, just picked up a '94 DX manual with 70k miles and MINT interior for $500. Needs some maintenance done, but I can't wait to get it on the road. Shifter bushings are shot so bad I couldn't even tell what gear I was in. Has an exhaust leak, busted up windshield due to hood popping up which is dented as well, and the clear coat is coming off because Florida but rust free! I'll be into this car under 1k after doing everything it needs, should be a great DD! I can post pics later if anyone wants to see.
  8. #4403
    Registered User yanyankee7's Avatar
    Join Date
    Aug 2015
    Location
    US
    Posts
    23
    Feedback Score
    0
    I got a question guys. Can i buy a dohc head to instal into a sohc motor?
  9. #4404
    Join Date
    Mar 2005
    Location
    305
    Posts
    7,998
    Feedback Score
    27 (100%)
    you know, instead of asking the same question in a bunch of different threads, you could try using the search feature.
  10. #4405
    Registered User cat34evr's Avatar
    Join Date
    Mar 2006
    Location
    Everett, Washington
    Posts
    401
    Feedback Score
    1 (100%)
    Replaced alternator and PS/AC belts, replaced ball joints and sway bar end links. New alternator on Wednesday, didn't want to eff with the belt in the waning daylight so did that yesterday.
  11. #4406
    Registered User
    Join Date
    Sep 2013
    Location
    Lake Zurich, IL
    Posts
    40
    Feedback Score
    0
    Got around to installing the master cutoff switch, have to have it according to sanctioned drag strips for batteries that are relocated to trunk. I may try to find a more appealing sticker, the white is a little too much for me.
  12. #4407
    Join Date
    Mar 2005
    Location
    305
    Posts
    7,998
    Feedback Score
    27 (100%)
    registered it today. car-related costs down here are insane- insurance is more than twice as expensive and getting the registration/title was $428 (in CT it would have been like $120ish + taxes, which are like ****-all on a 14-year old car with 189k).
  13. #4408
    Registered User
    Join Date
    Sep 2013
    Location
    Lake Zurich, IL
    Posts
    40
    Feedback Score
    0
    I titled and registered my car that was 3 years expired (not turning in title) in Minnesota and it was less then $90 out the door. Would've been $380 in my home state (Illinois).
  14. #4409
    Death To Cones!!! SgtRauksauff's Avatar
    Join Date
    Jan 2004
    Location
    Baraboo, Wisconsin, USA
    Posts
    2,456
    Feedback Score
    6 (100%)
    yesterday, I moved my BPT from the hoist where it's been for the last long time onto an engine stand. and realized that all the little bolts that I had lined up are gonna be a PITA to remember where they go. and I might be missing one of the MBSB bolts. Are the four bolts that hold the collar for the rear main seal to the block two different lengths, since the thickness of the collar is slightly thinner on the upper bolts?
  15. #4410
    Rough & Dirty User worldhazard's Avatar
    Join Date
    Oct 2004
    Location
    Central Oregon
    Posts
    2,781
    Feedback Score
    17 (100%)
    scratched a 'new' valvecover today... thinking of getting it painted soon. will likely be the only asthetic piece to the 'build'
    1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
Thread Information
Users Browsing this Thread
Similar Threads
  1. GI part out of my 93 lx
    By Turpro in forum Protege's and Other Cars For Sale Only
    Last Post: 11-25-2010, 07:21 AM
  2. What is this part?
    By PBCrunch in forum Engine/Drivetrain - BG Chassis
    Last Post: 06-24-2009, 04:40 AM
  3. 93 dx part out
    By 92_2_fast in forum Parts and Misc. Items For Sale Only
    Last Post: 10-12-2007, 07:06 PM
  4. anyone want to get me a part?
    By shaggyhair in forum General Discussion - BHA Chassis
    Last Post: 09-10-2005, 10:59 PM
  5. Name the part...
    By RALLYBP_94 in forum Engine/Drivetrain - BG Chassis
    Last Post: 04-27-2004, 12:19 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
